Tomei Arms Round 2!!!!!
Old Dec 7, 2009 | 07:03 PM
  #106
dmotors's Avatar
http://www.tomeipowered-usa.com/usa/...7960/m7960.htm
turbine housing data
evo9 gsr std 10.5
tomei arms 10.5 a/r 77
Old Dec 7, 2009 | 07:15 PM
  #107
burnzy's Avatar
dude.. they're both 10.5 meaning both a/r's are .77
Old Dec 7, 2009 | 07:40 PM
  #108
dmotors's Avatar
i initially thought it was the same exhaust housing but if you look inside both housings they have a diference , and is bigger inside .
Old Dec 7, 2009 | 08:52 PM
  #109
burnzy's Avatar
were you looking at a e8 or e9 turbo, as e9 turbos are .77 AR from mitsubishi too
Old Dec 8, 2009 | 03:00 PM
  #110
Jorge T's Avatar
The Tomei hotside is wider to acomodate the thicker & wider turbine wheel and the casting is matched to the gasket. It looked OK until the oil burnt off and some water got to it, it rusted badly, more than the e9 10.5 OEM hotside I've had for 4 years.
Old Dec 8, 2009 | 03:12 PM
  #111
Kracka's Avatar
IMO its a good idea to get the turbo housing ceramic coated inside and out on any turbo, sounds like this would beneficial especially on the Tomei since it uses a different grade of cast iron than the factory housing.
Old Dec 8, 2009 | 04:26 PM
  #112
Jorge T's Avatar
Tomei came through! Got home today to find the replacement. I'm going to do a 1 to1 visual comparison, I wish I had a micrometer to measure thickness all the way in there and report back this weekend.
***the new hotside casting is different no numbers on the sides of the inlet and there is a tomei logo on one side, looks better overall. Also it is machined totaly different visually, I can see now the difference; the machined part was done wrong and ate into the volute.
Old Dec 8, 2009 | 05:46 PM
  #113
aka.ralliart15's Avatar
^^^Good to hear.
Old Dec 9, 2009 | 12:35 AM
  #114
Peter10654's Avatar
Sounds brilliant... Few pictures would be fine
Thanks a lot
Peter
Old Dec 9, 2009 | 01:42 AM
  #115
AJR-Coco's Avatar
so basically which serial number does the hotside can produce a crack during 1000 miles? i just bought my arms turbo but haven't installed it yet, is tomei doing a full free warranty on it?
Old Dec 9, 2009 | 01:47 AM
  #116
AJR-Coco's Avatar
I just found out my tomei on the hotside housing it has the tomei logo on it..so does that clarify as the newer version?
Old Dec 9, 2009 | 01:56 AM
  #117
AJR-Coco's Avatar
Anyways got some pictures to reconfirm this
Basically i think is July to august shipments from tomei had false hotside turbo housing "All the pictures that were posted with broken housing has no logo on the exhaust side"
The one i bought is a little bit different, because there is a logo and i think is new version! please let me know if I'm wrong but also for the tomei website all the hotside , ehxaust housing don't have the tomei logo on it
Old Dec 9, 2009 | 06:17 PM
  #118
EviL_IX's Avatar
hey guys, just another tomei owner here and got tuned last night. just wanted to share some numbers.
cosworth 272 m2
ets 3.5" intercooler
intake, intercooler piping
tomei arms, 02 housing, downpipe
resonated test pipe
2.75" catback-no resonators
stock IM, EM, TB
440whp 393wtq @26psi on E85 - on a DynaPack Dyno
So, im assuming the numbers may be a little higher on a Dynojet dyno???
Either way, im very happy and the car pulls strong all the way to limiter.
Old Dec 9, 2009 | 07:08 PM
  #119
Jorge T's Avatar
Yours is the new version, look at the machinig on the hotside facing the center cartdrige and look ant the pictures posted here, you'll be able to see the difference.
The piece that cracked open [more like blew out] on mine is paper thin. I dont think there will be a problem with this one at all.
Old Dec 9, 2009 | 07:18 PM
  #120
batty200's Avatar
DynaPaks typically read HIGHER than a dynojet since there is no wheel weight to rotate.
Congrats either way.
