Sandmonster: IX, E85, BR3065..
Old Oct 21, 2009 | 08:06 AM
PeteyTurbo@KHC's Avatar
Updated: 10 sec. stock motor BR3065
*update*
Here are the new numbers.. Have not been able to get off a full pass on this setup but went 104 in the 1/8th with this setup and the car holds a best time of 10.6 and 133mph before this tune. Full weight, stock cams, stock longblock from TB out..ECU boost designed to keep Tq. down ang gain hp..Any questions feel free to ask. We used the new Perrin EBCS PRO and I have to say it is my new favorite..Still have some fine tuning to do, we were kind of pressed for time during this session..These are all 3rd gear pulls, latest graph is uncorrected.
Sandmonster had asked me to post his results yesterday so here it is. IF it is not on the mod list it is stock, his car is fairly lightly modded. He had made 440hp prior to this retune and was trapping 126 in that form at 27psi. He has since added a doublepumper, here are the results.
Mods:
BR3065 cast manifold
BR doublepumper
AMS FMIC
HKS exhaust catless
RC1200's
Intake
MBC
This graph shows how rich the car was running after the doublepumper install versus removing some fuel and the power that was gained with no other changes in boost or timing.. It gained more then I thought it would from just fuel changes on E85 honestly. This is also not a finished product but I thought it was an excellent comparison..
This is the HP/TQ curve of the finished product at 32psi tapering to 29.5..
This is a comparison to his stock turbo numbers, this power level was good for over 114mph on the stocker.
Old Oct 21, 2009 | 09:53 AM
project_skyline's Avatar
You should bump your filtering up quite a bit more, that graph looks like ***.
Power looks good for mods, good work.
Old Oct 21, 2009 | 10:05 AM
I prefer a filter value of 1, I really could care less how pretty it looks, but thanks for the kind words..
Old Oct 21, 2009 | 10:12 AM
YNGEVO's Avatar
Nice work. I cant wait to dyno my e85 setup on stock turbo. Im trapping 118-120 on 22-23psi in that texas heat. J-Tune..
Old Oct 21, 2009 | 12:49 PM
jjm4life's Avatar
nice work there peterturbo. 440 on that dyno is a monster.
Old Oct 22, 2009 | 08:12 AM
It's actually 466 now read the graph
Old Oct 22, 2009 | 08:39 AM
4kinboost's Avatar
That turbo kit still kicks a$$!!
Great job Petey. Any gains from more boost?
Old Oct 22, 2009 | 09:07 AM
It picked up some power but not as significantly as say a t3 35r.. This kit uses a mitsu 7cm setup..Went to E-town last night but didn't get a clean pass (only got 2).. First one went almost 100 in the 1/8th and let off (botched shift to 5th 11.3@117 w 1.9 60') and second run the ic pipe blew off after turning up the boost.. I think he is going back friday..
Old Oct 22, 2009 | 09:11 AM
4kinboost's Avatar
Originally Posted by PeteyTurbo@KHC
It picked up some power but not as significantly as say a t3 35r.. This kit uses a mitsu 7cm setup..Went to E-town last night but didn't get a clean pass (only got 2).. First one went almost 100 in the 1/8th and let off (botched shift to 5th) and second run the ic pipe blew off after turning up the boost.. I think he is going back friday..
What rpm are you shifting at?? Where's the limiter set?
Old Oct 22, 2009 | 09:14 AM
It's not my car and I wasnt driving, rev limit was set at 8200 but he didn't hit the limiter either.. He is running a bad tire size 235/40 but waiting for a set of the 245/45 drag radials to arrive. Can't see why it would not be an easy 10 second car like that..
Old Oct 22, 2009 | 09:16 AM
4kinboost's Avatar
Springs and retainers + 8500 limiter should keep that car in 4th on a 10sec pass no?
What do the 60fts look like?
Old Oct 22, 2009 | 09:23 AM
1.95 60 foot lol, the car has an evo8 4th gear.. He just needs tires I would think..
Old Oct 22, 2009 | 10:35 AM
evoforlife's Avatar
nice setup for the street
Old Oct 22, 2009 | 10:42 AM
jjm4life's Avatar
touche' peter.
Old Oct 22, 2009 | 10:48 AM
hempele28's Avatar
Another solid tune as always pistol. So many people cast the 30r off saying it was out dated. Clearly it still performs very well. I'll see you in a few weeks at the shower buddy.
