FP Black on Pump vs. Stock IX Turbo
Old Dec 15, 2009 | 05:28 PM
yahu's Avatar
Damn, I wanted to see the graph. Is it going back up? PM it to me, OP!
Old Dec 15, 2009 | 05:31 PM
jusa4bngr05mr's Avatar
+1 He is just showing a comparison with the same boost levels...... with 6 to 8psi more, it would be a world of diff!
Old Dec 15, 2009 | 06:52 PM
mitsuevo803's Avatar
+2 i think that turbo was meant to run 30+ psi...
Old Dec 15, 2009 | 09:19 PM
Lucas English's Avatar
It more or less showed what yours did, no real changes +45whp.
Old Dec 15, 2009 | 09:46 PM
scheides's Avatar
EvoM Moderator
a) stupid this wasn't posted in teh dyno section
b) extra silly for not including any other mod info, boost level, or tune info on either turbo setup
c) seriously, why would you buy a black for a car you plan on only running 24psi, pump gas? My BBK made 430whp on a dynojet pretty easily at 24psi, and has a lot more bottom-end. BBK or HTAGreen are a better choice for a setup like this.
Old Dec 15, 2009 | 10:00 PM
GST Motorsports's Avatar
Originally Posted by JohnBradley
We have seen 3900 for full boost (seems to not matter how much boost) on the black.
3900? C'mon aaron the red doesn't even spool that fast. What gear are you talking about here?
- bryan
Old Dec 15, 2009 | 10:06 PM
06MREvo's Avatar
but -20wtq though...
Old Dec 15, 2009 | 10:18 PM
Boltz.'s Avatar
FCOTM Winner
- bryan
+Eleventy billion.
There's no way a black will spool to 35+psi as quickly as it will spool to 20psi. Also, if we are talking about 3rd gear dyno pull at a reasonable starting rpm show me 3900 and I will eat my foot. Usually you're on point Aaron, and I'm sure you didn't mean anything by it, but.... really?
Old Dec 15, 2009 | 10:35 PM
Maybe he is posting at the bar?
/me raises glass...
- Bryan
Old Dec 16, 2009 | 12:34 AM
Svendiesel's Avatar
I thought just under 4000 was about correct for full spool on a black , no??
Old Dec 16, 2009 | 04:01 AM
localtoys73's Avatar
my red 3800 spool on stock cams
Old Dec 16, 2009 | 05:09 AM
NitrousOxide's Avatar
This isnt a good thread to be honest.. We need to see the limits of Black on pump!! 27-30psi please!!
Old Dec 16, 2009 | 05:24 AM
ethan169's Avatar
interesting.. Im seeing 25psi at about 3700-3800rpm on my stock VIII turbo with S2's....And you guys are saying the red or black will see similar boost levels at 3900 but giving me much more power and torque?
Maybe i should just go straight to the black??
edit: No one actually said it will give me large gains but i guess I would expect some pretty large gains from the stock VIII turbo with supporting fuel mods etc. Just wanted to clear that up
-Ethan
Old Dec 16, 2009 | 05:40 AM
crcain's Avatar
It depends on gearbox ratios but I thought it was like, for 30 psi in 3rd gear, something like this:
Green - 3800
Red - 4200
Black - 4500
And of course, each turbo would make 20 psi much earlier than 30.
Old Dec 16, 2009 | 06:17 AM
scheides's Avatar
EvoM Moderator
Originally Posted by rockbmx1
Maybe you should STFU?? Have you had first hand experience with the black? Has Aaron had first hand experience with the black?? Aaron has, so I would trust his imput with the spool.
Bite your tongue, sir. There are 115,000 members on this forum, and Bryan (GST) probably has more experience tuning all sorts of turbos on evos than 114990 of them, maybe more.
This would depend on the gear, and what you define as 'full spool' ....25psi? 35psi? 40psi? From my experience, a red spools 25psi around 3800-3900, and the black is almost certainly a few hundred rpm behind that.
you turbo 2000 lag lifters thermometer poking
