FP Black on Pump vs. Stock IX Turbo
Old Dec 14, 2009 | 04:33 PM
turbooutlaw1976's Avatar
Here is the configuration:
06 IX GSR
* Stock IX motor (bone stock)
* Stock cams
* Stock head
* Stock exhaust manifold (no porting)
* 3" Agency Power exhaust - turbo back
* Meghan O2 housing
* Buschur 4" I/C + BR I/C Pipes + Forge BOV
* Tune by "Big Al" - DynoFlash
* Dyno Used - Pruven Performance
* Boost level - 24PSI (IX turbo), 24 PSI (FP Black)
* 880cc Precision Injectors
* 255LPH pump
NOTE: These results compare the stock IX turbo to the FP Black on a healthy stock IX motor @ the same boost level. An Aquamist is being installed and I will post the "high boost" graph.
NOTE: These results are real. I have no reason to post false data. I'm just an everyday Evo owner sharing results.
Here are the results:
Old Dec 14, 2009 | 04:40 PM
-Evo Aaron-'s Avatar
Interesting, good numbers for pump, quite a bit more lag
Old Dec 14, 2009 | 04:41 PM
JohnBradley's Avatar
Nice, how much boost were these two pulls? Not really alot more lag, different start points on the dyno pull dont help. We have seen 3900 for full boost (seems to not matter how much boost) on the black. The black is only about 200rpm more lag than the Red.
Old Dec 14, 2009 | 04:46 PM
bluebanana23's Avatar
Thanks for posting the graphs. Too bad it wasn't done on the same day but nice too see another comparison. How come you haven't upgraded cams yet?
Old Dec 14, 2009 | 05:01 PM
Actually, it was 24 PSI
Old Dec 14, 2009 | 10:16 PM
shuttlegoose's Avatar
can't see the pics
Old Dec 15, 2009 | 01:33 AM
NitrousOxide's Avatar
cant see the pic as well!
Old Dec 15, 2009 | 02:48 AM
bbyevo8u's Avatar
please post the dyno sheet again! why did you take it down?
Old Dec 15, 2009 | 02:55 AM
boostedtres's Avatar
dyno sheets?
Old Dec 15, 2009 | 05:58 AM
JakeTheVIII's Avatar
Yea what happened?
red03evo's Avatar
where's the info?
Old Dec 15, 2009 | 06:03 AM
[I.R.A.]_FBi's Avatar
no sheet
Old Dec 15, 2009 | 02:41 PM
240Z TwinTurbo's Avatar
Originally Posted by JakeTheVIII
Yea what happened?
When you make a post that shows someone spent $2,000 for 45hp@wheels that is bad for business
Old Dec 15, 2009 | 05:17 PM
mitdrx's Avatar
I was just thinking the same thing
Old Dec 15, 2009 | 05:20 PM
CMB's Avatar
CMB
^ you guys are in the dark. That turbo is just getting warmed up at 24 psi.
