EVO DYNAMICS STRIKES AGAIN - pure_evo, (411whp/394wtq; 30PSI; E85)
Old Dec 28, 2009 | 02:43 PM
  #46
Levar's Avatar
Veteran: Army
Originally Posted by alicea8541
What the other guy was referring to was your stock knock sensor. With the Tephra mod, when the knock sensor detects knock it will flash your SES light.
Originally Posted by nikkadanny
why you would not have a knock sensor? our cars come with a knock sensor from the factory.
I understand about the knock sensor. When I saw the SES light come on, I took the car to Autozone for a diagnostic check. It read "O2 sensor bank one". I called Kevin and he told me that he was sure that it was just the rear O2 sensor since I have a test pipe and that it was nothing that I should be worried about.
Originally Posted by 05blue8
Tuners will generally make the tune as agressive as you want them. As for mine he told me when I had knock and we backed it off until there wasn't any and he felt safe. There is a pretty big issue here and it's that if you are in 5th gear at WOT the car does not and can not control boost as if it was 2nd, 3rd, 4th gear. My car is tuned for spike of 32 PSI and in 5th gear at higher RPM's at WOT I've recorded a spike to 37 PSI but thanks to the knock sensor nothing was hurt. Depending on how your tune was set up and the temperature it's pretty obvious things got pushed past their limits. In colder weather the air is denser and you are going to push more boost. I wouldn't be surprised if you hit 35-36 PSI and without the knock sensor to control it this is what can happen. Every car is different, every tuner is different but I would stand behind Kevin 100%. If he does the rebuild he can let you know what happened. It sucks, no doubt, hopefully you're back up and running sooner than later
It was pretty cool the night it happened. Like I said, I had a goal in mind of 375whp/375wtq that I kept to myself. As things progressed, I just assumed that the car was handling the boost rather well. In no way am I specuating and I'm not questioning or doubting Kevin at all. Like I said, I more than likely pushed things way too far.
Originally Posted by andrewzaragoza
also it is best to get it tuned at a higher gear if you will push it hard at 5th since you will hit different loads in different gears.
Originally Posted by RockmanX
so are we to assume kevin tuned him at a lower gear and he decided to push it hard in 5 and because of the spiking boost created lots of knock and that in turned doomed the motor???
My tune was done in third gear.
Originally Posted by Evo_Kid
Mamba is what he call his car i believe.
Yes, I call my car the Mamba but there are plenty of TB EVOs out there that are more deserving and more well-built.
The stock block limit is about 400-420TQ, which this car was very close to.
Is this a documented fact?
to the op keep us updated on what you find when you open up the motor. also posting your timing maps would help the people here see if you were past MBT.
Yes, I'll keep everyone abreat of the situation in the days ahead. I'll try to upload a few ECU Flash images of my timing maps later this evening.
Old Dec 28, 2009 | 03:14 PM
  #47
Kracka's Avatar
The rear o2 sensor SES light can be very easily disabled with ECUFlash.
Old Dec 28, 2009 | 03:20 PM
  #48
Evo_Jay's Avatar
Yes, I would say its a fact that the stock block limit is around 400-420TQ. Im sure others will confirm.
Also, you may wanna talk to you tuner first about posting images of the timing maps. Its actually against EvoM rules to post vendor maps.
Old Dec 28, 2009 | 03:25 PM
  #49
KevinD's Avatar
here is the log from the tune on the car:
you can see nothing out of the ordinary. max torque timing was around 5 degrees, peak timing was near 20 degrees. that is a typical E85 tune (some are more aggressive yet). you can see two 1 count of knock but that is nothing to worry about (not rod throwing knock), and the timing is not beyond MBT as noted by the repeated runs we did with improving torque figures every time.
the AFR and boost curves are on denvers laptop, but the boost was not above 30psi, and AFRs were in the low 12's on a gas calibrated wideband. (12-12.3AFR).
Old Dec 28, 2009 | 03:29 PM
  #50
Evo_Jay's Avatar
Cool. Log looks good, and timing seems perfect for E85.
Im pretty sure now that the reason for the failure was just that was the TQ limit for that stock block.
Would you agree Kevin?
Old Dec 28, 2009 | 03:52 PM
  #51
KevinD's Avatar
some engines fail. simple as that. it really sucks when it happens, i know first hand how it feels (and on my old porsche of all the cheapest cars to replace motors in ). i've seen ring lands fail on pump gas, stock turbo, low boost tunes, and i've seen stock motors make into the 530+whp range on stock everything. we should take everything apart to see what if anything is discernible from the damage (rod bolt let go, boost line of wastegate pop off, fuel pressure regulator vacuum line pipe off, wastegate stuck shut, could be any number of reasons, including knock, bad E85, boost spike, etc...) knock is usually pretty easy to see on the piston tops if that was the case. it could just be a weak rod.
Old Dec 28, 2009 | 04:00 PM
  #52
Evo_Jay's Avatar
Yep, stuff sometimes just happens.
Keep us updated.
Good Luck
Old Dec 28, 2009 | 04:13 PM
  #53
nikkadanny's Avatar
Originally Posted by YNGEVO
Hey man i am right there with you. I got a J-tune on e85 on my evo at about 70kmiles stock motor. I was on 23lbs and i wld make 30psi meth evos look slow. I was trapping 117-120 range on 23psi falling to 30. So at 91k miles i go back and have a re-tune. I wanted 30psi so i cld race this friend of mines c6 z06. Well i get it tuned on 30psi and 1st gear tires no good, 2nd gear tires still no good, 3rd gear-hold on tight. **** was crazy. Long story short a week later i was going up a hill and gave it too much load, prob doing 40 in 5th gear. All of a sudden, boom.. Piston 1 had completly fatigued and decided to give up. It completly shattered cause me to throw a rod and put 2 holes in block. No sign of detonation. Tune was dead on. I was astonished how much beating my stock motor went through. Dnt worry when it is built with a bigger turbo, u will look back and laught at the fact. Wish the best of luck.
Originally Posted by xxblazexx
dude im just saying i been tuned on a high amount of boost more than yngevo like i said 27-28 psi and we both been running our cars hard on the streets cause people are just to impressed by the stock turbo.. your car should have been able to take that beating...
same situation different tuners. like kevin said some engines fail some dont.
Old Dec 28, 2009 | 04:43 PM
  #54
Nissan2Evo's Avatar
Gared's car was running at those power levels for over 20k miles, lasted him over a year, too many races to count. Just saying...
Old Dec 28, 2009 | 04:54 PM
  #55
Evostacio's Avatar
Well this really sucks for the op. Now he's got no car.
Well I been running my evo at least 1 time a week a whole night vs some muscle cars that just can't believe the stock turbo is capable of what it's doing and my car is going strong. Well if it makes a come back I'm sure it's gonna be one hell of a build
Old Dec 28, 2009 | 05:01 PM
  #56
RockmanX's Avatar
true true but building the evo when you did not have any intentions to do anytime soon sucks period.
Old Dec 28, 2009 | 06:25 PM
  #57
nikkadanny's Avatar
do you want a cookie?
Old Dec 28, 2009 | 06:54 PM
  #58
KevinD's Avatar
congrats. i have 500+whp on stock motor still. still even have stock head studs, i have 90k miles on the car, 35k with the 35r and meth injection running 32 psi. nothings broke yet, but sometimes it happens. my car gets beat on many times a day, every person who visits the shop and asks for a ride, hard pulls from a dead stop, many track days (NOTHING is as hard on a car as a track day, not even remotely close), autocross, and of course the stuff your implying .
i'm going to help Pure_evo out as much as possible, and hopefully we can find out why it failed.
Old Dec 28, 2009 | 07:16 PM
  #59
Evostacio's Avatar
^^^ well glad your evo didnt blow up!!
and yes i would like a cookie thanks
Old Dec 28, 2009 | 07:43 PM
  #60
vegas702evo's Avatar
Good Luck with the car man. Some cars can take the beatings and some cant. Not all Evo's are the same for which why there's CUSTOM tunes for them.
