EVO DYNAMICS STRIKES AGAIN - pure_evo, (411whp/394wtq; 30PSI; E85)
Old Dec 28, 2009 | 09:05 PM
  #61
norcalSRTrida's Avatar
s*** happens. so let me get this straight though...you dont have a boost gauge, nor a wideband?...and you're running around at 30psi?
i know its a time to be somber, but come on dude. atleast take some initiative to protect your investment. get the necessary guages, and datalog your pulls!
seems like your tuner is fully capable, and knows what he's doing. user error, or just a weak motor. rebuild w/ some nice forged internals, and boost on.
Old Dec 28, 2009 | 11:49 PM
  #62
soceur77's Avatar
subscribed, Ill give you a call when i get off quarters Levar
Old Dec 29, 2009 | 08:41 AM
  #63
BOOSTEZ's Avatar
Originally Posted by xxblazexx
^^^ well glad your evo didnt blow up!!
and yes i would like a cookie thanks
What's your car making and mods?
Old Dec 29, 2009 | 09:53 AM
  #64
Drooke's Avatar
very nice!!
Old Dec 29, 2009 | 12:20 PM
  #65
lude2evo's Avatar
nice, sorry to hear you blew the motor. second one ive heard of in the last few months
Old Dec 29, 2009 | 04:35 PM
  #66
Levar's Avatar
Veteran: Army
Originally Posted by KevinD
here is the log from the tune on the car: you can see nothing out of the ordinary. max torque timing was around 5 degrees, peak timing was near 20 degrees. that is a typical E85 tune (some are more aggressive yet). you can see two 1 count of knock but that is nothing to worry about (not rod throwing knock), and the timing is not beyond MBT as noted by the repeated runs we did with improving torque figures every time. the AFR and boost curves are on denvers laptop, but the boost was not above 30psi, and AFRs were in the low 12's on a gas calibrated wideband. (12-12.3AFR).
Kevin, thanks for posting the log and I'm glad that you've chimed in with the thread.
some engines fail. simple as that. it really sucks when it happens, i know first hand how it feels (and on my old porsche of all the cheapest cars to replace motors in ). i've seen ring lands fail on pump gas, stock turbo, low boost tunes, and i've seen stock motors make into the 530+whp range on stock everything. we should take everything apart to see what if anything is discernible from the damage (rod bolt let go, boost line of wastegate pop off, fuel pressure regulator vacuum line pipe off, wastegate stuck shut, could be any number of reasons, including knock, bad E85, boost spike, etc...) knock is usually pretty easy to see on the piston tops if that was the case. it could just be a weak rod.
Totally agree as this is what I've said from the beginning.
congrats. i have 500+whp on stock motor still. still even have stock head studs, i have 90k miles on the car, 35k with the 35r and meth injection running 32 psi. nothings broke yet, but sometimes it happens. my car gets beat on many times a day, every person who visits the shop and asks for a ride, hard pulls from a dead stop, many track days (NOTHING is as hard on a car as a track day, not even remotely close), autocross, and of course the stuff your implying . i'm going to help Pure_evo out as much as possible, and hopefully we can find out why it failed.
Reading through the comments, I can see the sarcasm starting to pick up. Can we not take things "there"? Seriously, this has no effect on anyone's pocket book except my own. I only want to get things diagnosed as there will be no way that I'll be able to get the car fixed before I leave for Arizona meaning that the car will have to sit where the rebuild is going to happen. I would like to do things right this time and maybe entertain other options of achieving my power goals that does not include E85 given the fact of various ratings between comparable gas stations.
Originally Posted by norcalSRTrida
s*** happens. so let me get this straight though...you dont have a boost gauge, nor a wideband?...and you're running around at 30psi? i know its a time to be somber, but come on dude. atleast take some initiative to protect your investment. get the necessary guages, and datalog your pulls! seems like your tuner is fully capable, and knows what he's doing. user error, or just a weak motor. rebuild w/ some nice forged internals, and boost on.
Yes, I do have a boost gauge and as I've said earlier, I bought the wrong AFR gauge by mistake. I completely agree with you about getting forged internals with a rebuild. It will be done right once that time comes. Right now, I'm just trying to decide what the best route is and the timeline associated with it.
Quarters? What's the matter? I bet it's the typical Iraqi winter getting the better of you.
Old Dec 29, 2009 | 05:20 PM
  #67
Levar's Avatar
Veteran: Army
I'm ready to proceed with the rebuild as time is not a commodity I have very much of.
Old Dec 30, 2009 | 06:43 PM
  #68
evoevo8's Avatar
i am sory for you man it suck you didn't even get to enjoy the new power. so i guess you not going to buy my 9 turbo huh lol jk. hope you luck on the next build. just wonder if because you park your car for 3-4 month without even start the car if that have anything to do with the motor blew?
Old Dec 30, 2009 | 07:51 PM
  #69
Levar's Avatar
Veteran: Army
Yes. I'll still buy it from you as I want to go the ported IX route.
Old Dec 30, 2009 | 08:01 PM
  #70
Levar's Avatar
Veteran: Army
I'm just getting things ready for my rebuild. It's going to be a long process and truly a test of patience. I just don't want to go through this ever again so bulletproof for the engine and drivetrain is the name of the game from now on.
https://www.evolutionm.net/forums/sa...44k-miles.html
https://www.evolutionm.net/forums/sa...vo-8-head.html
https://www.evolutionm.net/forums/sa...-diff-lsd.html
https://www.evolutionm.net/forums/ev...s-package.html
Old Jan 1, 2010 | 06:42 PM
  #71
05blue8's Avatar
Everyone kept asking me why I had Kevin do a bottom end build when he did my 60k service, I went with Howard 1000 hp rods and wiseco HD pistons, full head work, dual springs, 272's...because I knew what was coming. I just put on my 35R and will be going with alot of meth and I want to go f a s t, I say do it right the first time, at least as right as you can. Glad you're getting it taken care of, good luck
Old Jan 2, 2010 | 06:39 PM
  #72
RockmanX's Avatar
so kevin put that all together and its running A1??
Old Jan 4, 2010 | 09:47 AM
  #73
Levar's Avatar
Veteran: Army
I'm not sure I fully understand why you mention that you had your bottom end rebuilt but then list parts that deal with the cylinder head. I was in the process of doing things right as springs/retainers were next on the list of parts to buy. I do wish you a lot of fun with your 35r/meth set up.
Old Jan 4, 2010 | 04:46 PM
  #74
Motor-Rx's Avatar
Sorry to hear that had happened.
GL with rebuild
Old Jan 4, 2010 | 06:24 PM
  #75
poormanevo's Avatar
to the op, what kind of dyno is this?
