Epic Motorsports 443hp & 417tq 93oct
Old Feb 14, 2010, 08:00 AM
warp9's Avatar
Originally Posted by blackgsx01
well the 25psi actuator hasnt been adjusted yet, I was wondering if that would help me hold boost. I am considering setting the turbo up for external wastegate. I am using a hallman pro boost control with the heavy spring.
I have had the Hallman act funny on me and was giving me boost creep. I would switch it out or take it apart and give it a cleaning. Sometimes the ceramic ball gets stuck to the base. See if that helps
Old Feb 14, 2010, 08:56 AM
blackgsx01's Avatar
Yea I was going to order a rebuild kit for it, and adjust the acuator alittle. I hope it will work, I really didnt want to setup for external, I like the stock appearing look.
Old Feb 14, 2010, 04:08 PM
1slowassevo's Avatar
THere could be many other factors why the boost is falling t 25 psi..I agree thats rather low expcially on 30 psi it should hold 29 to 28 psi with the right combo tune etc.etc.etc..I would check my bov,b.c.then finally if that doesnt't help then last the wastegate...i use to hold 27psi then i changed my upper intercooler pipe and bov and now im holding 30psi,to 29 psi at 7,900pm.s
Old Feb 14, 2010, 04:48 PM
EvoFlash's Avatar
Let me start off saying awesome number and I'm only asking because I'm about to order a fp black my self and have similar mods to you. Merlin just made a post of his 450whp at 26 or 27psi with pretty much the same mods except with a red.Same fuel 93 oct .This was on awdmotorsports mustang dyno. His mods list below. Shouldn't you be making more???
Mod List:
-FP Red w/FP Intake
-Halman Pro MBC
-Ets 3.5 fmic..Ets licp/uicp
-Rc 750cc injectors
-Buschur Racing stock ported tb/mani
-Greddy Ti-C
-QTP dp
-Walbro 255
-GSC S2 cams
Old Feb 14, 2010, 05:36 PM
Force-Fed Performance's Avatar
No reds/meth make around 450-460 on our dyno.
Old Feb 14, 2010, 05:44 PM
freshevo8's Avatar
Not to discredit the power that car made at AWDmotorsports, but look again as that is a DYNOJET dyno. No doubt that is impressive but the mustang dyno at epic that Red car would read a bit lower.....
Old Feb 14, 2010, 05:45 PM
red cars on pump make around 420 @ Epics Mustang
Old Feb 14, 2010, 06:27 PM
nikkadanny's Avatar
Mod List:
-FP Red w/FP Intake
-Halman Pro MBC
-Rc 750cc injectors
-Greddy Ti-C
-QTP dp
-Walbro 255
-GSC S2 cams
I am pretty sure awdmotorsports has a dynojet not a md.
Old Feb 14, 2010, 06:42 PM
Evoryder's Avatar
Mod List:
-FP Red w/FP Intake
-Halman Pro MBC
-Rc 750cc injectors
-Greddy Ti-C
-QTP dp
-Walbro 255
-GSC S2 cams
As stated before, AWD has a dynojet. Dynojet read higher than mustang dyno's. The car in this post is a black, Merlin(450whp @ awdmotorsports) has a Red.
Old Feb 14, 2010, 06:53 PM
EvoFlash's Avatar
O Man I could of swore it was a Mustang dyno sorry about the confusion. I'm glad cause I'm just about to order my fp black lol.
Old Feb 14, 2010, 06:57 PM
freshevo8's Avatar
So its in your sig and not installed yet? Hmmm.......If in fact you have the rest in your sig, along with a few other supporting mods, you should see some nice numbers also. Good luck...
Old Feb 14, 2010, 10:41 PM
JohnBradley's Avatar
I can completely believe 509-511 wheel at this boost level. The 2.4 car we did earlier last year for Johnny was making its power/torque on a 27 spike dropping to 24.5 or so out the top. I am sure this will generate some flack but its my feeling that the bigger motor uses more air and while the boost isnt as high the over all air mass being used is the same. If we did it on 92 and low timing, I am sure that 30ish and MORE timing will make the same power on a smaller motor.
Power is often in the details of the combo, do one thing that affects the combo and you globally affect power. I am not saying anything about the 450 that was done on the dynojet since I havent read that thread. Every car is in itself different, some have awesome head castings and some are pretty weak from the factory. Not all cams are created equal even from the same manufacturer. Lots of little things add up.
Again though to Robbie, Bobby, the OP, and the crew there congrats on some good power.
Old Feb 15, 2010, 10:23 AM
blackgsx01's Avatar
Thanks for the comments everyone. I hope to fix this minor boost problem and maybe shoot for alittle more on 93oct. Maybe 460-475? I plan on doing some lightweight parts now(driveshaft, batterykit,mustache bar,diff mounts,front crossmember). I just want a mid to low 11sec 1/4mile for a daily driver..........for now.
Old Feb 15, 2010, 10:24 AM
you shouldnt have any problem with that now Ross
I will get ahold of the graph tomorrow and post it up
Old Feb 15, 2010, 10:47 AM
blackgsx01's Avatar
thanks justin
Quick Reply: Epic Motorsports 443hp & 417tq 93oct
