Mikey's E85 FP Red 535hp
Eric good to see you are still alive! I miss you dude, in a non homo way
Go ahead and order anything you need for the swap and I'll hit you up with the $$$ to cover the parts. Also I want that 38mm you have. I think I'm going to order the large and small blue spring to equal 23psi.
I would like to have everything swapped over the second week in March. I'll come up and help you bust it out in two easy laid back nights. I want to dyno on the 13th. I sent you a PM that you might like
Aaron, I'm going to need your help on the 6th and 13th of March for dynos if you can meet me a DO. Let me know.
Mikey
Go ahead and order anything you need for the swap and I'll hit you up with the $$$ to cover the parts. Also I want that 38mm you have. I think I'm going to order the large and small blue spring to equal 23psi.I would like to have everything swapped over the second week in March. I'll come up and help you bust it out in two easy laid back nights. I want to dyno on the 13th. I sent you a PM that you might like
Mikey
GD we need E85 in Seattle/Kent/Auburn/Tacoma valley!!! I wrote Cenex a few letters but havent heard anything back. Sorry for OT but everyone that has E85 local should take a second in silence
I run E85 and live in Auburn. Snoqualmie Ridge is only 20 miles away. Buy some gas cans.
Gateway Gas, 8030 Douglas Ave. SE, Snoqualmie, WA 98065
I live in Kent which is right next to Auburn and Mapquest says its 44 minutes / 36.47 miles which is a little too far for me. I have thought about it in the past though because I have so many gas cans. I should have listened to Aaron and got 1000cc+ injectors and be done with it because with the 780's I'd have to upgrade to run E85 obviously. *edit* I'm really thinking about making the switch now though, I may have located a few new 55gal drums and I have room in the garage
Just have to hear back from Aaron.
