BBK Full 91 octane Evo 9
Old Feb 27, 2010 | 01:58 PM
Chris Moore's Avatar
Straight Arizona 91 octane. VDR graph with smoothing at 6 in Evo-M mode. The log was taken on a completely flat road, outside air temp 67° F.
Mods:
BBK Full Turbo
3" TBE
3 Port Mac BCS
Perrin Intake
AMS LICP
Perrin UICP
Ported Stock Exhaust Manifold
PTE 1200's
AMS Front Mount
Kelford 272's
PSI based boost at 24 psi.
Power would obvisouly be lower or higher depending on the dyno mode setting, but this is what the Evo-M mode was designed for.
**Edit** Added a new graph below per Boosted Tuning's suggestion
Old Feb 27, 2010 | 03:23 PM
xcelr8's Avatar
nice power. Its odd to me however that the peak power comes on so late in the power band. I would expect more power at around 5500rpms. maybe just the vdr? congrats
Old Feb 27, 2010 | 03:25 PM
I think alot of it might be VDR, but the car as actually always made peak power right around redline. Since it is a 6 speed, perhaps a 4th gear pull would look better.
Old Feb 27, 2010 | 03:53 PM
rgar's Avatar
Nice hp number, but I was hoping to see a little more torque personally. Your setup is very close to what I will have shortly...
How's it feel?
Old Feb 27, 2010 | 03:56 PM
How's it feel?
Feels great, Overall it runs awesome on the street. Its not a big turbo high hp car, but its what I wanted for the time being. The power jump at the end is not nearly as bad with a little more smoothing either.
Old Feb 27, 2010 | 10:00 PM
Boosted Tuning's Avatar
That spike at the end of the HP plot is likely incorrect.
Use "max RPM trim" to correct it. You'll need to set it about 100-300 before the end of the log. Try all the setting and you'll see a trend. That is the correct curve.
Also, use dynojet mode. Its hard to compare Evo-M mode to anything since its an imaginary dyno.
Old Feb 27, 2010 | 11:06 PM
Edited first post. I kept the first graph up too so people can see the difference in the settings. Power and curve stayed the same with a 7700 and 7600 rpm max trim. The run actually went to 7844 rpm.
Also bumped smoothing up to 10.
Old Feb 27, 2010 | 11:21 PM
ohhgyeahfasho's Avatar
Try starting your WOT pull at a lower rpm, like 2600-2800 RPM, instead of 3,000+. Your starting it a bit too late IMO. And what does your boost taper to?
Old Feb 27, 2010 | 11:27 PM
Obvisouly if I was tuning or going for the fasted spool I would do so, I just finally had a log on a flat road so I thought I'd post it. Boost holds 24 psi to 8000 with the 3 port. WGDC in the low 80's by 8000.
Old Mar 8, 2010 | 12:28 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Those are huge injectors for 91. Switching to E-85 anytime soon? Just curious.
Do you think your powerband is so high due to the Kelford cams?
Old Mar 8, 2010 | 01:02 PM
ravnos04's Avatar
[quote=golgo13;8072337]Those are huge injectors for 91. Switching to E-85 anytime soon? Just curious.quote]
+1...If no E85 where you are at, will you be adding any meth?
Old Mar 9, 2010 | 10:23 AM
Magnumpsi's Avatar
Oh snap!
Nice power dude!
Give me a shout Chris I am back in the country.
Mitch
Old Mar 9, 2010 | 10:39 AM
scheides's Avatar
EvoM Moderator
Excellent graphs! Great street setup! Crazy how power keeps going up after 7000rpm, that's the only thing that seems weird. Even with that though, power looks just dandy for those mods.
Old Mar 11, 2010 | 12:35 AM
Yeah I have been running e85 in the car for almost 3 years. I have just been playing with 91 lately. No meth. Fixed a few boost leaks today as well so Ill have to make a new graph and see if I gained anything.
Ill be calling you tomorrow Mitch.
Old Mar 11, 2010 | 12:37 AM
Maybe, I didn't do the before after testing that I should have.
kreionic
624
Nov 29, 2011 05:04 PM
boosted91t
Nov 29, 2011 07:44 AM
KevinD
North Texas Evo Club (NTEC)
21
May 4, 2011 03:15 PM
CBRD
Jan 29, 2010 07:42 AM
GST Motorsports
Dec 23, 2009 10:43 AM
