Dyno tuned today
Old Mar 11, 2010 | 01:38 AM
cbareng's Avatar
Dyno tuned today
We dyno tuned today and hit some reasonable numbers on 92 octane @21psi......358.66 awhp 360.02 awtq
MODS:
AEM EMS
AEM 5 bar map sensor
AEM AIT sensor
MAP downpipe with external dump
GSC S1 cams
850cc clinics
Walbro 255
ETS 3.5" intercooler
Muse upper and lower I/C pipping
HKS titanium exhaust
3" piping not cat
Megan manifold
Stock IX turbo
Apexi boost soenoid
K&N cone filter
NGK Iridium 1 step colder plugs
Gates racing timing belt
Old Mar 11, 2010 | 04:09 PM
phishy's Avatar
Solid GL reaching your goal!
Old Mar 13, 2010 | 01:53 AM
cbareng's Avatar
Major problem tonight
Driving in second gear, about 3/4 throttle car bogs alittle then all of a sudden the engine dies...I was able to pull over and try and start the car once again....I have a real hard time starting the car and seems as if theres no compression. I finally got the car started and noe the car sounds like a Suby. I manged to drive the car down the street to my tuners shop. He first checked the spark plugs and found that cylinder # 4 spark plug was bent alittle, then compression checked all the cylinders and found that cylinder #4 compression was lower than the rest. Funny thing is that the car doesnt emit smoke out of the exhaust and after everything was put back together we fired it up and ran normal... the head/motor will be taken apart tomorrow to see the extent of the damage. I hope and pray that its not going to be an engine re-build...lmk what yall think
Old Mar 13, 2010 | 02:13 AM
MR. EVO MR's Avatar
that sux the big one, you just tuned her too, #4 took a dump, what was the previous power?
if you take her apart just do a drop in if you don't have to many miles on her.
GL
this thread will be locked too because you never posted the chart
Old Mar 13, 2010 | 02:42 AM
cbareng's Avatar
GL
Previous power with only a Megan downppipe, Apexi power intake and, MBC off ECU flash was Dynoed @298 hp and 300 tq
sorry the graph will be up tomorrow my scanner is down
Old Mar 13, 2010 | 08:41 AM
MR Turco's Avatar
need a dyno chart for this area. Pm me when you have one to reopen.
Old Mar 13, 2010 | 03:44 PM
MR Turco's Avatar
open
Old Mar 13, 2010 | 09:42 PM
evocivicmarc88's Avatar
Power seems really good especially only at 21 pounds.
Old Mar 13, 2010 | 11:59 PM
cbareng's Avatar
I know but i dont know what went wrong the day after. All was fine the night of the tune...my tuner thinks it might have happened because im not running springs and retainers with the GSC S1 cams, but they arent recommended...I actually started up the car tonight to see if any IC pipings came off, but they all seemed fine...also the car started up fine ran normal...WTF???...The head will be taken off Monday first thing to diagnosed the problem.
Old Mar 14, 2010 | 12:03 AM
cbareng's Avatar
GL
DROP IN MEANING??? I just made 50k miles on her
Old Mar 14, 2010 | 12:33 AM
Evo_IX_Guy's Avatar
Hey I live in mililani, I see you got tuned at rad's just curious here but who tuned you? I know there aren't any really good tuners here in Hawaii which is why everyone waits for Chris from AMS to come down.
Old Mar 14, 2010 | 01:16 AM
CUCOS BISH's Avatar
not bad.. good numbers
Old Mar 14, 2010 | 04:50 AM
cbareng's Avatar
We got 362 hp and 389 tq on one of the pulls @ 25psi on the stock IX turbo but I wanted the car tuned @ 21psi with the HP and TQ about the same too be on the safer side and he accomplished what I wanted. He is a very good tuner!
Old Mar 14, 2010 | 12:02 PM
Evo_IX_Guy's Avatar
Ok I know Seth and he's pretty cool, he put in my cams. Anyway keep up informed on what's going on with you car. Hope it doesn't turn out to be a big problem.
Old Apr 12, 2010 | 12:33 AM
cbareng's Avatar
MODS:
AEM EMS
AEM AIT sensor
GSC S1 cams
850cc clinics
Walbro 255
3" piping not cat
Megan manifold
Stock IX turbo
Apexi boost soenoid
K&N cone filter
If i were to upgrade to a FP Green can I break the 400hp barrier with my setup?
