BBK Full turbo 93 octane
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Mike's car I can say has been tuned properly and other then age there is no reason to build the block unless he has money and want more HP. I was tuned by the same tuner and I'm making a bit more power then Mike especially since my my retune with the Grimmspeed EBCS and with 65k daily driven I can honestly say our blocks are safe
my car only has 43k on it and i daily drive it as well. 25psi is believe it or not pretty safe and i rarely punch it.
The Shop is in Norwalk CT by the way.
Dballz i think i may have found my idle problems. i noticed a black residue near the oil cap and the PCV valve so im guessing i have a leak there somewhere. i am going to try and fix that to see if my idle improves.
Great to hear guys, thanks. That's what I wanted to hear because I have a daily driven 03 with 75k, and seeing so many results like this from the BBK sure gets me itching to bolt one on.
Like I said, don't be afraid! I have been making 300whp (dyno dynamics) on my car since 30k miles, and I have just shy of 80k on the clock right now; stock bottom end! By about 45k miles it was making 360whp/350wtq and I put the BBK on at ~63k miles and have been making 420whp/390wtq since then. If you want to max out the stock bottom-end, but not push it, this turbo is the one to get.
Nice #'s, post ur graph in https://www.evolutionm.net/forums/ev...ts-thread.html
Not to brag, but if you think your car is scary you should come take a ride in mine im puting out 560 whp and 440 wtq on pump gas at 30 psi with the fp red. I was scared when junior was test driving my car, all of a sudden when he hit full boost in my cat I got thrown back in the seat and i was like wtf.
evo4life400 good numbers on the bbk.. im in the process of upgrading from my 9.. and want sumthing simillar like u got.. i got pretty much ur same setup cams and all.. lol.. my goal is the 400 to 450 range on pump.. have u raced any other evos with big turbos.. how does she hold up with the bbk.. does she pull good on top also..
as soon as they give us independent date, we will release them..
and good news... for those with BBK's... the upgrade price to the B will be VERY VERY reasonable!
cb
TACH_MOTOR_WORK
Feb 21, 2012 01:08 PM
Wiznaz
12
Aug 11, 2007 04:39 PM
