575whp on 6262 setup...opinions on whats wrong with my graph?
Today I'm going to check timing. I'm also going to verify with GSC that the cams in the car are indeed S3's. At the same time I am going to perform a compression test. Within a week or so, I will probably replace the Magnus IM with a Buschur ported (just need to find one). I also need to find a buschur testpipe back exhaust. So if anyone has a used one, please PM me. I am very determined to find the problem. Hopefully the issue isn't too costly.
We're all rooting for you!!
Where did you buy the cams? If you got them used, maybe the original owner could confirm with his own proof of purchase?
Cams were bought new from Javicracer here on EvoM. I PMed him to give me reassurance that these were in fact GSC S3's. He replied that they were S3's indicating why they were so difficult to sell. I am in contact with Greg at GSC in order to determine which cams these are. I should hopefully have an answer by the end of today on that.
You guys keep saying intake manifold/exhaust.. neither of which would make the cars power SO DAMN CHOPPY at the end...choking off maybe, but it would be a smoother more gradual decline. A few things ive seen in cars that have made it chop like that(if your saying the boost held steady then ignore the first two)but a cracked manifold at or around the wastegate which would explain the late spool up and fluctuation or boost leak that the WG and turbo are trying to overcome, bad timing,valve float,bad spark, or something else is not working properly. Again, im a V8 guy but even having the wrong cams(installed properly) if too small would just dip and not chop THAT bad. And ive heard "unknown shop" said twice in this post and he mentioned Headway performance as the builder of the block.
If you notice the power starts to go back up..toward the end a little..if the exhaust was choking it it would just keep going down..not pick up hp after it dropped off.
also you you to remember bobby has a big set of cams in there thats what cams do is make the power band go up..It looks like the manifold,cams,and exhaust are competing against each other for flow..
the car will be at my garage in 20mins or so. ill gunna pull the exhaust off and see if it makes a difference(which i know it wont) but just to make everyone happy i will. If i can remember correctly Sumans car has a buschur exhaust on it with 2 magnaflow resanator mufflers and the car makes 700+ on pump as with a similar setup. im convinced that intake mani and cam combo along with incorrect timing is the issue.
I have a resonated testpipe and another resonator on the midpipe and a huge muffler... I dont think a true 3" exhaust can create so much backpressure...
The OP is missing a LOT of power! I would put my money on the intake, cam combo
well....there is some issues. i believe my head is the problem. compression number are as follows: #1-85 #2-120 #3-95 #4-125. I have no oil in my catch can, so it doesnt seem to be rings. the head will be coming off and sent off to a machine shop. could be seal(s)? bent valve(s)? i guess we will find out. Im going to go ahead and thank Bosco for taking time out to help me discover all of this. its truly appreciated. im sure he will chime in here soon.
take it off and the drop might be more
