575whp on 6262 setup...opinions on whats wrong with my graph?
Ill do a little chiming in. With the center two pistons at TDC and pumping compressed air into each cylinder...cylinder 2 holds steady with no leaks but cylinder 3 you can hear air leaking out of the exhaust(enough to even spin the turbine wheel) and out of the valve cover breather hole making me think its a bad valve/valve seal. Same thing is happening to one of the outside pistons at TDC(forget which one) When the engine was built the head was left untouched just had the cams swapped. It has the same dual springs he bought the car with as well as the factory(yellow/brown?) valve seals.
As I said from the start it looks like more of a mechanical problem with engine than a restriction.. if its not timing as we now know then bent valves possible or hurt pistons..
Mike
Mike
Don't forget, bent valves or bad valve seals can also do that. The air has nowhere to go but up through the valve stem into the valve cover. #3 had some coming out of the breather tube as well.
Today we did a leak down test, all 4 cylinders have between 0-1 percent leak down. after that we re-did the compression test with a battery charger hooked up to the mini battery.
#1-125 #2- 120 #3- 125 #4-125. then we checked the cam sensors and they were both installed correctly. then we re-checked the cam timing and it was also good. now we are back to square one. the manifold is coming off and the gsc junk (so called) "s3s" are also coming out. and back to the dyno to make power.
#1-125 #2- 120 #3- 125 #4-125. then we checked the cam sensors and they were both installed correctly. then we re-checked the cam timing and it was also good. now we are back to square one. the manifold is coming off and the gsc junk s3s are also coming out. and back to the dyno to make power.
Mike
S3s power 1117whp, revise statement please.
Check the reluctor on the exhaust cam, seriously. Valves are bent or not, 0-1% leakdown is obvious thats not the problem. They only have 11.5mm of lift and 238@1mm duration so they arent hitting, I dont think they would even hit on stock pistons. I am running a similar combo right now with 12mm lift and no issues
