Full-Race Twinscroll 40R
can you weigh a 90 degree elbow in 1.25 and in 1.5?
I'm curious how much lighter per bend they are. Will you sell them? I will need enough for my manifold when the 7670 or the 7064's become available
And...after I get married
Jeff got the car fired up this morning and was going to dyno tune it today, but the Fuelab fuel pressure regulator I have on the car just can't handle all the flow from the new fuel system... Going to get a new fuel pressure regulator on the car and hit the dyno soon...
i would wire up the second pump to come on under boost or you will have a tank full of really hot gas if you drive it for long distances. what regulator are you going to? weldon?
Weldon A2040 - I would opt for a cooler rather than having a second pump activate under boost, never liked those setups...
yeah, im going to be running 2 044's with a surge tank and dont like the idea of the 2nd pump failing to activate either. on my sti i had a single 044 and after a couple hours on the freeway the pump would start screaming and i would have to stop and pump a few gallons of cool gas in the tank to shut it up so i dont like the idea of running 2 full time. i wanted to run both full time but off a pwm map at low duty cycle under cruise, but i heard the 044's do not like that at all.
I'll be monitoring the temps and if they become an issue, I'll install an external fuel cooler... I don't want to do it unless necessary because it's just something else to leak/fail...
I'm surprised you where having issues in your STI - I've been running an external surge tank with an external 044 on my STI for years now and it's been flawless... We did pay a lot of attention on how/where we ran the fuel lines and added heat shield to the lines in areas that heat was potentially an issue...
Definitely changing up your setup will help - I have taken long, and very spirited trips in the STI and never had an issue...
The event has a rain date and they may postpone it if there's a likely chance of rain - Ira, Jonathan and I are ready to go if it's not canceled - only change will be if Keri goes into labor...
Wise guy - my EVO is not one of those 'street cars' that gets put away for the winter, rain or anything but a 1/4 run a couple times a year
Some comparison results - both on same boost level, low 30's - Original setup is the dotted lines, new mods solid lines...
There's no compressor left in the 40R - but we are ready now for the BW 9180 that's on the way
Full-Race Mid-Size Runner Manifold, ID 2200cc injectors, Dual Bosch 044's at 50 psi base pressure and 76% injector duty cycle
