Retuned for 2010
Old Jun 2, 2010 | 11:05 AM
neonglh's Avatar
As long as you are happy, that is all that matters bud
Old Jun 2, 2010 | 01:10 PM
Broham's Avatar
Originally Posted by BEISSEN
thanks,Also seems like you got a good amout of your installed. Did you do it or pay a shop?
this stuff was installed long ago, just did brakes. ill be chillin with you to do the ic though,battery reroute/gauge setups. lookin good man.
yea, meth is not really a "safe" thing. stick with e85 if you can.
im not sure who has the lowest reading dyno, but this does read lower than dynojets and some mustangs. it's just a tuning tool really.
Old Jun 2, 2010 | 03:00 PM
red03evo's Avatar
nice #'s.
Old Jun 2, 2010 | 04:48 PM
EmeryatSTM's Avatar
Look please if you want to turn this into a dyno queen thread go else where, the proof of a dyno is on the track but everyone knows all shops claim to have the lowest reading dyno to compete all I know is that the butt dyno tells me my car is alot faster and when I can pull a car on my friends Evo IX and he put more down but at the same place I know my car is faster now.
Well, my car makes about 650 whp on my dyno and Buschurs dyno.
Here is what it runs
http://www.youtube.com/watch?v=m_kFQZKl9jA
Please show me a dyno dynamics Evo that makes similar power and runs near the same as ours. Im interested to see what you come up with.
Thanks
-Em
Old Jun 2, 2010 | 05:08 PM
LGshow19's Avatar
i love that angle... just pulling on those evos... just walking em...
Old Jun 2, 2010 | 05:28 PM
BEISSEN's Avatar
Originally Posted by EmeryatSTM
Well, my
Thanks
-Em
Never said what dyno is best please stop putting words in my mouth. I stated the proff is on the track. A dyno is only a tool for tuning not exact numbers.
Old Jun 2, 2010 | 05:50 PM
Noize's Avatar
EvoM Administrator
Originally Posted by neonglh
First of all, I have a hard time beleiving that a dyno dynamics would read lower than our mustang dyno, either STM or Buschur. What does a bone stock Evo put down on that dyno?
Well, they do read pretty low, I used an one identical for years. Here's some reference numbers for you, man.
A stock VIII makes 205whp.
My stock IX made 215whp.
My stock X made 222whp.
My VIII needed a full exhaust, a Mitsu titanium 10.5 turbo, 272 cams, cam gears, pump, and tune to make 305whp on a DD. But it ran 12.3 at almost 113mph on that power in summer heat. A friend with an old VIII on a 30R went mid 11s and trapped 122mph on 392whp.
Just an FYI on the comparison.
To the OP, I would suspect the top end power fall off is due to the fact the car is an VIII and has no Mivec. Can gears will fix that top end at the expense of a little spool. If you already have cam gears, retard the intake one a little more.
Old Jun 2, 2010 | 06:06 PM
BEISSEN's Avatar
I don't have came gears just cams. What are good cam gears to go with? I am running comp 272 cams I/E.
Old Jun 2, 2010 | 06:13 PM
Noize's Avatar
EvoM Administrator
Just about any reputable ones will work.
Just make sure your installer and tuner are familiar with that brand, because some of the early ones were set for DSMs and were off a tooth.
For 272s, I found -3 intake/ -2 exhaust to make the best power up top with much less taper than you are experiencing now. Good luck.
Old Jun 3, 2010 | 03:45 PM
BEISSEN's Avatar
I was looking and the HKS are desined around the Early DSMs so I might end up with AEM, But I will wait until I get more stuff to get tuned with before installing them because the dyno is 500 more. I will wait till I upgrade the Turbo and injectors first then add the cam gears with it and timing belt.
Old Jun 3, 2010 | 07:06 PM
FJF's Avatar
FJF
... the proof of a dyno is on the track...
What does the car run?
Old Jun 3, 2010 | 08:26 PM
BEISSEN's Avatar
I have not got the chance to goto a track with the car. When I first got
It I had to replace the head gasket returned replace the mbc fix several boost leaks and holes in the pipeing and just got the car back in decent shape. I am now working during the days the track is open.
Old Jun 4, 2010 | 02:51 PM
BEISSEN's Avatar
Here is the reply from the shop I goto since its LOCAL said about their dyno.
" Sorry it took so long for me to get back to you.
Anyways, our dyno is calibrated as set from factory with zero correction factor. It reads ~12% lower than a dynojet, ~15% lower than dyna pack and ~18% lower than a dynomite dyno. "
I have no clue personaly what all this means but for the Shops that keep cring beucause they swear there dyno is the best when I never said that my shop was you read this and leave it at that. This is not a "Who's dyno is better thread" so if you want to have a argument on that start your own thread. No one here can say theirs is lower then everyones because I gureentee you have not been to every other shops dyno room/facility and tested it. STM you have a fast *** and nice car and can tune great you have proven that so stop coming in here and acting childish please. Why post a vid of your car with pulling laundry? Is it for self satisfaction?
Josh@Spec-Ops
EvoX 'For Sale' External Engine / Power
Aug 31, 2012 08:10 AM
BEISSEN
16
Jun 26, 2011 05:36 PM
BEISSEN
Jun 3, 2010 07:40 AM
BEISSEN
Jul 4, 2009 08:30 AM
