Mikey's LR2.4 FP Black E85 Break-in Tune
ACT Xtreme PP & street disc.
My Tq numbers are close to what the advertised limit is on this clutch combo. So far it is holding fine, I'm sure if I started launching on it though, it wouldn't last long!
When my block let go last winter, I already had this clutch sitting in the garage, so I just used it and spent the funds in other areas. Not sure I would have chosen this clutch if I had forseen the 2.4 in my future.
The only annoying feature is if I let the car 'bounce' on the rev limiter, it doesn't want to shift. As long as I shift at 7900 or sooner though, it works just fine.
John-
John-
https://www.evolutionm.net/forums/ev...-problems.html
With your displacement and black i would think even the Exedy would not be so happy after some spirited driving but i would imagine much better than the ACT.
Best of luck
Erik, you will need a Triple. I had the Twin HD and it is really easy to get to that 550tq mark. I'm not even at 600hp yet and I'm already beating down the door to 550tq. The 2.4s usuallly only make 60 mor hp than tq. I assume your setup will be 625-650 range fairly easy so you will be 575+ tq.
Mikey
Mikey
Also, what is the service life of a triple? I don't want to be changing the clutch every 20,000 miles.
Here in Seattle there are some really steep hills and I stalled trying to go up a hill that I go up almost everyday in the Twin and never had a problem. Now with the Triple I have to rev between 4.5-5k and slip the clutch out... If not it will just stall.I wouldn't say it is near as good as the Twin for DD but the clutch pedal feels the same as the Twin and acts the same in traffic, sore leg, but overall the Triple is a great clutch so far. It grabs much harder than the Twin and I like the added comfort that my Twin HD couldn't have given me at this torque level!
I think the life of a Triple is 20-25k from what I have read. The spline/spindle (I think that is what it is called, have to double check) goes out on them quicker than the Twin...
Mikey
I've driven it and don't see what all the "hype" is all about as the pedal pressure is on the harder side and the action w/ the pull type set-up just doesn't feel great.
I guess when compared to my QM it is much more streetable but f-in costly
Still no magic clutch for us higher hp/tq guys that like to drive on the street still
ZR1... All in good time. If I ever get to 800hp, then I might try!
I don't see 800hp anytime soon. Unless I go 3586 in the winter...
Mikey
Mikey
Juvy can drive a triple (she weighs 90 something wet and wearing boots), and I personally have felt that other than cost the Exedy triple (non carbon) is hard to beat. It will hold pretty much any amount of torque i have been able to put to it.
aaron
We have a customer that runs an Exedy triple in his Evo and he really does not care for it.
Mikey
Mikey
Eh so thats what the triples are supposed to last eh? That sorta sucks lol. I drive a lottttt so I hope I can get it to last 30,000+. I only see me being at the track maybe 2-5x a year with the car and the rest will be like 95% highway miles.
im sure the clutch will do fine long as you are taking it easy majority of the time but then again im just worried about day to day alot of pressure on the petal but again you will get used to it. LOL I never knew my evo had a exedy twin in there and i was like man this clutch is tight but got used to it after that 22hr drive LOL.
Nice numbers man!
Just curious, not sure if you said it since i didn't read all the posts, do you have a goal in mind for the car? Numbers you are hoping for I guess? I am about to venture down the FPblack road myself.
You should. I could not be any happier with the Black. It spools great and keeps making power. Feels much different than the Red above 6k.
Mikey
All I want to see my car make on BR's heartbreaker dyno is 500-530 and Ill be pretty happy, those numbers should equate to around 600 on a dynojet. If we happen to hit any higher Ill be happy as a pig in sh*t. I really have no clue what to expect.
