BBK Full + GSC S2s + Grimmspeed ECBS + Boomba Racing
Old Jun 11, 2010 | 10:54 AM
scheides's Avatar
EvoM Moderator
Originally Posted by Strictly Modified
398 On a Mustang Dyno?
You know it! BBK's can make great power with the right parts combo
Old Jun 11, 2010 | 11:00 AM
Strictly Modified's Avatar
Good to know, considering this was done on a mustang dyno also.
-Cisco
Old Jun 11, 2010 | 11:15 AM
CBRD's Avatar
yes, on our AWD500SE
stock evo ix makes 225-230 on a good day
cb
Old Jun 11, 2010 | 11:16 AM
CBRD's Avatar
-Cisco
PM me if you need any info!
im always happy to share.
cb
Old Jun 11, 2010 | 11:24 AM
Thank you sir.
Old Jun 11, 2010 | 12:41 PM
Boomba Racing's Avatar
Originally Posted by cij911
on 93 you should be able to have a peak of 25 psi and hold more like 23 at redline w/o a knock issue....that single change alone should net you close to another 30 hp....
I was happy with the power the car made, but more importantly so was the customer. But the car was knocking, epically in the upper rpms. When I pulled some timing the knock wasnt there. It wasnt real bad but it defiantly got my attention. As you guys know tuning is a balance between timing, fuel, boost, ect.
To put more boost at the car reacting like this would not be beneficial. With this car, on that day, in my opinion it was not a good idea!
Damian: I want to try some different gas when you come back in. In this area shell 93 seems to be the best. What gas was in the car?
Bottom line is the car still made good power, especially for 22psi!
CBRD's turbo FTW!
Devin @ Boomba Racing
Old Jun 11, 2010 | 03:56 PM
Blitz's Avatar
Hard to say. I always use either Mobil, Shell or Citgo.
Old Jun 11, 2010 | 04:11 PM
MJ23FE's Avatar
Originally Posted by CBRD
Glad you like it!
we typically run the bbk's at 26-29 psi on 93 (even road race cars)...
the torque will take a big jump.
I did a 30psi 93 tune about 2 weeks ago in 90 degree heat and it made 398/391
cb
I WANNA SEE!!!! What mods did this particular car have?
-Jalal
Old Jun 11, 2010 | 06:37 PM
EVO8LTW's Avatar
Glad you like it!
That really surprises me. I'm in the process of trying to get my Black dialed in for the track and the EGTs are hitting the verge of unsafe levels at only 24-25 psi on straight pump, and the Black has a more free flowing turbine than the BBK. If you have any data on EGTs with the BBK, I'd love to hear it. To combat the EGTs, I'm working on reinstalling my Aquamist kit for water injection before turning up the boost any further.
Old Jun 12, 2010 | 11:43 AM
JohnBradley's Avatar
What are unsafe EGTs? Turbine technology is at the point today where as long as there isnt boundary layer disruption in the head, running 1600* isnt as bad as it was 10 years ago...even 5 years ago. AMS TA1 car would get the header glowing with a 35R and it didnt seem to mind.
EGTs can be contained with AFR, timing, and/or fuel. Water in and of itself isnt necessarily going to combat the EGTs. I would run the biggest single nozzle that Aquamist sells (I believe the 1.0m) and run straight meth without altering how the car is setup.
High 10s for AFR, timing as high as you can keep it, and boost where you want it. A 20 min lap session with cool down doesnt seem to be a problem for our road race guys on gasoline and definitely not on E85.
Old Jun 13, 2010 | 04:22 PM
crand002's Avatar
These turbos rock. The OP defiantely needs more boost and needs to have that tuner bump up that torque.
Old Jun 14, 2010 | 05:31 AM
We are going to put the car back on the dyno with a fresh tank of gas in the car and see if it helps. We will keep you guys posted
Devin Tuned @ Boomba Racing
Old Jun 14, 2010 | 07:15 AM
CBRD's Avatar
In all honesty, I dont pay as much attention to EGT's as I used too... We have NEVER lost an evo motor here due to any tuning related issues and many of our cars are road race cars...
Most of our roadrace cars also run on 93.. I have one in particular with a stock block, 52,000 miles, does 2-3 track days a month, on a BBK with a cat running 28.5 psi, sometimes spikes to 30...
CB
Old Jun 17, 2010 | 02:01 AM
RickU's Avatar
I'm thinking about getting the BBK in the near future, but how much boost can i run safely with California's 91 octane?
Old Jun 17, 2010 | 02:54 AM
Tribal's Avatar
wow, very quick evo off the line.
