Virtual Dyno is available!
Old Jul 13, 2010 | 03:59 PM
  #106
Boosted Tuning's Avatar
Originally Posted by bbarnhill
Sorry to shoot ya down ... but Ive had every beta tester at my throats about this
Np. Just goes to show you got a lot of honest testers.
Old Jul 13, 2010 | 04:37 PM
  #107
Mellon Racing's Avatar
link in first post updated
Release Notes
1.0.4.0
- Fixed a bug where logs could have blank data in some cells and data in others of the same column
- Added AEM log support (must be exported in TEXT format)
- Access Port (AP) logs now supported
- AFRMAP removed from the AFR column list due to it not being an actual measure of AFR
- Fixed bug where if AFR has empty cells it would crash
- Fixed bug that would graph cells that should have been trimmed by the TPS trimming, this caused graph anomalies
- Changed loading time of logs to only when first loaded, which prevents loading all logs everytime the graph is redrawn
- Changed colors to be Red/Blue for first run loaded to conform with most dyno graphs
- Trim out data samples that have the same RPM as the previous row, which causes anomalies and high HP numbers
- Trimming of RPM now is live and doesnt cause graph to blink
- Graph quick action bar added to top right corner of graph (wont show up on print outs, or screenshots)
- Save graph image added to quick action bar
- Copy graph to clipboard added to quick action bar
- Print graph button added to quick action bar
- Toggle data points added to quick action bar
- Color changes for uniformity
- Default CF set to 1.09
- Store default image for the graph background
- Limited loaded runs to a max of 4
- Default tire sizes for all vehicles were set to the stock tire size
- Legend wording reworked to show weight and remove one unneeded entry
- Tire size calculator button added to the RunControl, next to the TireSize text box
- Changed versioning to shorten the length of the version the user will see to 3 digits ex. (1.0.4)
Old Jul 18, 2010 | 05:34 AM
  #108
testing has begun on 1.05
Old Aug 1, 2010 | 07:59 AM
  #109
Levar's Avatar
Veteran: Army
Chris, for those of us DSM guys looking to run the EVO8 ECU in either a 1G or 2G, could we also take advantage of this?
Old Aug 1, 2010 | 12:27 PM
  #110
bbarnhill's Avatar
Of course you can. You can add any car you want to the cars.xml just put it in the format in the file and itll be there for you to select when you drop your runs in VD.
Old Aug 2, 2010 | 06:06 AM
  #111
stryfetew's Avatar
What you set the smoothing too?
Old Aug 9, 2010 | 08:19 PM
  #112
1.05 is up http://www.mellontuning.com/index.ph...dex&cPath=1_28
please don't forget to hit the Donate button in the program, Brad worked very hard on this and shares it for free.
Release Notes
1.0.5
- Settings are now not saved on graph settings window close via the X
- Fixed a bug when renaming logs that caused a fatal error
- Fixed a bug that caused the FindRPMRange to return no range due to blank RPM columns
- Fixed a bug that would cause the TPS to be found and not trim blank columns
- Fixed a bug that would trim all values out even if TPS was found
- Fixed a bug that when closing a non-selected run
- Fixed a bug that when loading a file that contained blank rows
- Fixed a bug causing the AFR and Boost not to graph if either was not present
- Fixed a bug that caused lowered RPMs in the run to cause spikes in power
- Added adjustable Auto Trim TPS value to the settings screen
- Added cancel zoom button to the quick action bar
- Added car profiles to allow quick loading of car details
- Added ability to drag and drop profiles on runs for single run application of settings
- Increased speed of graphing by adjusting when columns are found
- Dynamic scaling of Boost and AFR graphs
- Load runs even if file is already open in another program (non-exclusive file access)
- Increased the sensitivity of smoothing but decreased smoothing on AFR/Boost
- Boost graphing on Y2 axis of bottom graph
- FindColumnName function added to remove redundant code
- Finding of column names moved to once per table to improve performance
- Added Evo 5 GSR (5 Speed)
- Graphing can be done in metric or imperial units now (HP/ft-lbs or kW/N m)
- Splash screen background set to transparent
- Splitters added to allow adjustable profile and runs panel
- Saves location of and size of window on exit
- Changed the smoothing number box in the settings window to a drop down list
- PNG set as the default image format to save graphs in
Old Aug 9, 2010 | 08:55 PM
  #113
bbarnhill's Avatar
Well thank you mellon ... Ive already started on Version 6 and supporting DSMlink .... sigh ... I dont see an end in sight
Old Aug 9, 2010 | 09:03 PM
  #114
stryfetew's Avatar
I love that new version.. Boost plot win win win.
Old Aug 9, 2010 | 09:07 PM
  #115
bbarnhill's Avatar
Stay tuned for changes stryfetew ... Im about to add a (for the lack of a better word) ****-ton of cars in the next version hopefully. Im trying to get DSMLink files supported right now ... there is a lot of changes coming, so just strap your self in ... put your tray tables in the upright and locked position and hold the **** on.
Old Aug 10, 2010 | 05:19 AM
  #116
cij911's Avatar
Working nice for me...Seems to be similar to VDR 5.7, but easier for me and I like the AFR and boost plots....Nice job...
I wish there was an easy way to determine 'appropriate' smoothing....For me, it seems to be 12...
Old Aug 10, 2010 | 07:05 AM
  #117
the smoothing that's necessary depends on the car. My car only needs 3-5 at the most, maybe it's the combination of the smooth tune and upgraded ignition system. Most of my customers need 5-10 smoothing on stock ignition. some need more.
Old Aug 14, 2010 | 12:36 AM
  #118
rnbguy's Avatar
where is evo7 on the menu?
anyone know what the wieght is for the australia evo vii gsr? so i can enter it into the virtual dyno.
Old Aug 14, 2010 | 06:06 AM
  #119
EvoPower81's Avatar
same here . I used the evo8 gsr for my graphs but dont know if they are the same. Also my air temps are around 100 here where i live can i change it to that or the 77 has to stay?
Old Aug 14, 2010 | 06:34 AM
  #120
I believe they are the same, brad is going to add other models in 1.6
if you turn on correction for weather it's basically telling you what the car would make in good weather, not what it's really making
