Virtual Dyno is available!
Old Jun 27, 2010 | 06:13 AM
Mellon Racing's Avatar
Hey everyone my friend and customer Brad Barnhill has been working on a standalone Virtual Dyno application. You can simply drag and drop your Evoscan log files into the program, tell it a few things about your EVO and viola! you've got a Dyno chart. You can even right click and copy or save the image file.
You can get the program here: http://www.mellontuning.com/index.ph...roducts_id=453
So go out and do a 3rd gear pull on flat ground and share your results with your mod list. I'll get us started:
Mellon Tuning EVO 8 5-speed GSR on my 245/40/18 tires
BR HTA86 @ 38psi on e85 700awhp.
Buschur 2.0L
Buschur Stage 3 head
Buschur BF272 cams (Might go to Kelford 280/274 cams for better idle with ac)
Buschur twin walbro fuel pumps
Buschur 3" tbe, test pipe, bullet muffler
Buschur 3" intake pipe + Mas adapter
Buschur UICP and LICP
Buschur Mini Battery
Buschur Race FMIC
Buschur COP
Buschur Fuel Rail
ARP head studs
PPI ported stock intake manifold
PPI 65MM throttle body
FIC 1650cc injectors (going to FIC 2150cc high impedence injectors for better idle/cruise)
Tilton Twin Disc Carbon clutch
Tuned by Mellon www.mellontuning.com
VS. MKC Dynojet
Old Jun 27, 2010 | 07:38 AM
rong.'s Avatar
Sweet!
That is some good stuff Mellon!
Old Jun 27, 2010 | 08:35 AM
hempele28's Avatar
this works perfect. thanks for sharing mellon
Old Jun 27, 2010 | 08:41 AM
JDavenport's Avatar
Wow, that matches the Dynojet very close.
Old Jun 27, 2010 | 09:31 AM
Creamo3's Avatar
What vehicle weight are you using to get it to replicate dynojet numbers?
Old Jun 27, 2010 | 09:35 AM
evo<3's Avatar
i cant wait to get dyno tuned and then try this and compare!
Old Jun 27, 2010 | 09:42 AM
I think I had ~ 3150lbs for my car and 365lbs for me and kevin being in the car
Old Jun 27, 2010 | 11:40 AM
3gEclipseTurbo's Avatar
Can you do 4th gear? Ill spin 3rd...
Old Jun 27, 2010 | 11:45 AM
yep
Old Jun 27, 2010 | 11:56 AM
Steed77's Avatar
Thanks guys.... very cool.
Old Jun 27, 2010 | 02:07 PM
MR Turco's Avatar
Please remember, when posting graphs from virtual dynos, you must include the dyno type and dyno settings being used. Thanks
Old Jun 27, 2010 | 03:46 PM
Fast_Freddie's Avatar
Veteran: Navy
Turco with this new program, the only thing you enter is car weight, gear and your weight...
Old Jun 27, 2010 | 04:03 PM
Boosted Tuning's Avatar
Incorrect. There is setting for what dyno and dyno correction factor. Its in the "options", under "file".
Old Jun 27, 2010 | 05:13 PM
personally i don't think anyone should be playing with that setting to keep the playing ground level. I wish brad would lock it down.
Old Jun 27, 2010 | 05:22 PM
Veteran: Navy
Sorry, maybe it is just my nature but I never had any intention of changing any other information...
