Buschur 2.3 + FP Black + 39PSI
Old Jul 10, 2010 | 05:15 PM
tscompusa2's Avatar
So im writing this review mostly for my car, but Id also like to give credit
where it is due as well. Id like to thank the following vendors/ people for
their knowledge and help as I built and road tuned my car.
AWD Motorsports - Thanks for giving me great customer service
Buschur Racing - Thanks for the great, powerful, and reliable motor!
CBRD Speedfactory - Thanks for building one of the craziest evo shops around!
English Racing / JohnBradley(Aaron) (Thanks for all the expert advice with tuning)
IVEYTUNE / Sean Ivey (Thanks for all the expert advice with tuning)
JID2 (Thanks for all the expert advice with tuning)
VR-Speed Factory - Thanks for sponsoring me Tiago!
Maperformance - Thanks for the great discounts!
SparkTech - Thanks for the strongest spark possible!
Appauldd - Thanks for sharing your knowledge with me with the stock ecu!
Batty - Thanks for helping me put engine together in my garage over winter.
MR.TURCO - Thanks for teaching me how to use ecuflash when I was a noob!
Kreionic - Thanks for tweaking my tune!
Rogue - Thanks for the misc suspension work and tips!
and the rest of the EvoM community.
My experience with CBRD was second to none. I didnt expect to see what Ive seen.
This shop reminded me of a hospital but for cars... yes it is THAT clean. This place is
absolutely amazing. Chad and the rest of his workers there were all very friendly and great
people to be around. I couldnt have asked for a better experience. Personally I dont think
I could have had a better experience.
Kreionic is a badass tuner and an awesome guy to talk to and have a conversation with. Extremely
friendly guy and very easy to get along with! I am more then happy with his results and his tuning
skills are awesome. He upped my road tune by a good 90WHP and 30WTQ and I have literally did
50-60 pulls to get my road tune where it was, so it wasnt a half ***'ed tune by any means!
The following numbers were achieved on a 97F day with 60% humidity. The weather was not in our
favor to say the least, and my perrin FMIC was not happy! I realize my cars not making the power it
should be at 39PSI, and the dyno WCF showed 551hp/486tq which is still only barely making it past
600 on a dynojet. This is not acceptable at 39PSI of boost, so the FMIC has to go! I will replace the
perrin FMIC with a Buschur Race FMIC & Buschur Lower piping.
The first 2 pulls we did on the dyno were my road tune. The first pulls made
All pulls done in 3rd gear. This is a true reading Mustang dyno.
#1 433/402 @ 33psi
#2 435/431 @33psi
Next we decided to start changing the timing & a/f. Charlie talked me through everything as he was doing
it which was cool. I watched the car from pull to pull make 20whp here and 20whp there, and kept going
until we slowly but safely stopped at 522/460 at 39psi. This dyno is definitely one of the true heartbreaker
mustangs and weather was certainly not on our side.
We ended up going from 13-14* uptop which was my road tune to 18* uptop. To say the least the car pulls until
you lift.. The FP Black is a quick spooling beast and continues to pull hard until redline.
Below is a video of the last pull which made 520/460
Heres the Graph and some pictures to show WCF and etc.
http://www.youtube.com/watch?v=cdQEeuYfBiY
I think the cars down about 50-70whp from what it should be. My road tune normally gives 1* at peak, while on the dyno it was pulling till -1*, which I know was killing power and I am almost certain it is due to the FMIC not doing its job properly.
Short mod list:
ENGINE
Buschur Racing 2.3L Stroker - Manley/JE
Buschur Racing stage III head
FP Black HTA82 (Ported)
Hallman Pro
ARP L19 Headstuds
FluidAMPR Crank pulley
Power Enterprise TB
Kiggly Racing: HLA Pressure Regulator
Sparktech non cdi COP
NGK BPR8ES (Gap: 0.22-0.24)
INTAKE / EXHAUST
MAP Rev3 Intake Manifold
MAP Ported exhaust manifold
MIL.SPEC 65mm TB
FP 80mm intake + Perrin filter
Forge Type RS BOV
Upper / Lower Muse ICP
Perrin FMIC (Retired for a Buschur Race core)
Cobb 3” TBE
Invidia o2 housing
Kelford 272/272
DRIVETRAIN
Shep racing Ultimate Trans
Shep racing Stage III Tcase
Exedy Twin plate HD
Turbotrix Clutch Stop
FUEL
Bushur Racing Double Pumper
FIC Bluemax 2150cc
ENGINE MANAGEMENT / OTHER
Tactrix openport 1.3u
Evoscan v2.6
AEM Wideband
AEM Oil pressure
AEM 50PSI Boost Gauge
Omni 4bar Map Sensor
Tephra v7
READ THIS TO SEE WHY MY POWER WAS DOWN WITH THIS SETUP: https://www.evolutionm.net/forums/8541351-post73.html
AND THIS IS AFTER RESULTS OF MY SELF ROAD TUNE IN KILL MODE TWEAKING TIMING & FUEL WITH BUSCHUR RACE FMIC:
a/f leaned out more + timing advanced 2-3* more at peak torque & 2* more uptop. ( ECU Mods to stop the ECU from pulling timing as well based on IAT's)
Boost log attached. If Chad can post the rest of the dyno data information it would be helpful as well. I know their dyno logs tons of things and we were logging boost on the dyno, but I attached omni4bar logs.
File Type: zip
522.zip (722 Bytes, 0 views)
Old Jul 10, 2010 | 05:26 PM
jezzy101's Avatar
Veteran: Marine Corp
Congrats.
Old Jul 10, 2010 | 05:31 PM
tscompusa2's Avatar
Originally Posted by jezzy101
Congrats.
Thanks man. Post yours up! You outdid all fp black setups so far except for AWDmotorsports.
Old Jul 10, 2010 | 06:00 PM
4G63Rules's Avatar
Talk to Buschur about the FMIC. He was wanting others using the Perrin FMIC to do logs on what the temp increase was from pull to pull. You definitely should talk to him and maybe invest in a Buschur race FMIC.
Old Jul 10, 2010 | 06:04 PM
mullen's Avatar
was this on 93?
Old Jul 10, 2010 | 06:06 PM
AndyStacy's Avatar
cant wait to see the results with the new FMIC and stuff. Should be a nasty car at 39psi!
Old Jul 10, 2010 | 06:43 PM
596736's Avatar
^^ its on E85. Is this on the stock ECU?
Congrats man. I wouldn't be too down on your numbers because I know that dyno reads low. But I agree, after looking at all your mods, the perrin piece is a possible bottleneck but I don't know the specs on that intercooler.
Old Jul 10, 2010 | 06:44 PM
21Evo-lution's Avatar
Good stuff!
Old Jul 10, 2010 | 06:51 PM
tscompusa2's Avatar
sorry, yes its on e85 and stock ecu.. its down quite a bit of power tho.
Old Jul 10, 2010 | 06:56 PM
nikkadanny's Avatar
bet it pulls hard..have you logged it with the dll?
Old Jul 10, 2010 | 07:04 PM
tscompusa2's Avatar
Not yet. I will do that tomorrow if the rain goes away. But I logged my road tune with virtual dyno at 33-34psi and it showed 586/540 and that same tune straight to cbrd only did 435/431 so i suspect its close to 700 on that program.. I will find out as soon as weather clears up and post that in here as well.
Old Jul 10, 2010 | 07:08 PM
1slowassevo's Avatar
Nice graph and I agree about it being down on power.
What was your air intake temps????From this it will determine if it's your intercooler or something else.
This power should have been achieved at 35psi with all your supporting mods you have..
Old Jul 10, 2010 | 07:13 PM
kreionic's Avatar
NC getting anymore exciting for you?
Didnt log ait cause the car didnt have an air temp post IC. Put it this way first 2 pulls back to back no changes between runs it lost 30 ft-lbs. Its been proved the perrin ic isnt the greatest ic out. Some of the data from the log is in the first post. boost did drop off up top bad to 33
tscompusa,
Glad your happy with how it turned out. We all agree theres a bottleneck in there. Im glad to see your swapping the perrin out for a garrett core. Regardless of the final power output gains are whats important we picked up the 90hp/30tq from start to finished from a very decent self tune already.
Old Jul 10, 2010 | 07:17 PM
tscompusa2's Avatar
In order to properly log these temps i need a different setup, airtemps on stock ecu are by the mass airflow sensor.. worthless in this scenario.
im still on the stock compressor pipe that comes from mitsu also.. the black elbow that comes off the turbo compressor outlet which goes to 1.5"? that has got to be screwing flow as well.
The Perrin FMIC specs are as follows: 25" x 11.75" x 3.5" ------ im being told it is the endtanks on the intercooler that are super restrictive.
Old Jul 10, 2010 | 07:25 PM
lillev23's Avatar
Good power man. The car is pulling very smoothly on the dyno. What type of power would that translate into on a dynojet? Oh yeah, your car is clean as hell man!
