What Should I Do
Old Aug 25, 2010 | 08:48 PM
tigerkill2007's Avatar
What Should I Do
Well I have been tuning my car for a while now and I would like ur input on what psi I should run...there is no knock...I would just like to know since I am not gaining anymore power but I am getting more tq and the car feel like it pulls alot harder...I won't go pass 32 psi...and won't be runnning 20psi...I would like to know if I should keep it at spiking 32 psi tapering to 28psi or lower it down to spiking 28 psi tapering to 26psi...and also just wanted to posted this up show how the fp black runs with the smaller 264 cams
Mods:
Fp Black
Stock Motor
Hks 264 cams
Stock Intake Manifold
3" TBE
Ebay Intake
Greddy 3" FMIC
Ebay LICP
Crushed Evo 9 BOV
1200cc Pte Injectors
e85 fuel
Old Aug 25, 2010 | 09:23 PM
Acree's Avatar
You desperately need to let your engine breath better. Try an ETS 3.5" core, LICP kit, and UICP kit, a decent o2 housing, and exhaust.
If you want to leave your setup the way it is, I would recommend 28 tapering to 26. You really have zero supporting for a turbo as big as the Black.
-Acree
Old Aug 25, 2010 | 09:31 PM
I have a 02 housing...hks 3 inch exhaust...I don't think my car is having that much of a problem breathing I know that it is just that I got a smaller fmic and cams other than that I think it is pretty good...LICP I got it...and I don't see the use for a upic cause it won't gain much from the pipe...bigger cams next year and fmic
-Acree
Old Aug 25, 2010 | 10:12 PM
Boosted Tuning's Avatar
Nevermind
Last edited by Boosted Tuning; Aug 25, 2010 at 10:15 PM. Reason: Thought it was pump gas.
Old Aug 26, 2010 | 05:04 AM
griffeyr's Avatar
Originally Posted by Diddy69Art
Do a right intake, bigger cams and fmic and everything should be good. I've been having a lot of problems with ebay intakes, i will never use them again. Go for a buschur or ams intake, they cost 60-80$ and are worth the money...
Don't forget, you're still on stock engine except of the cams. Be carefull...
Diddy
do the perrin....the filter alone is worth it
Old Aug 26, 2010 | 05:17 AM
ssg_petty_210's Avatar
What ever you do, dont boost anymore. Everyone knows the full potential of a black is at the boost level you are pushing it. The thing about a turbo is you do not want to push it passed its efficiency range. Once this is done, the turbo will not give you any more power, but will only blow hot air. I would upgrade to GSC S2 cams and valve train. Keep the boost where it is at. If you can install new cams, then I would maybe drop the boost a couple psi just to keep the turbo in its efficiency range.
Old Aug 26, 2010 | 09:17 AM
jtyler's Avatar
The way I read is it is that he wasn't asking for what his next mod should be but rather what boost he should run....
Do whatever you're comfortable with. Like they said above remember you are on a stock motor and such. If you want to be safer go 28, if not keep it at 32.
Old Aug 26, 2010 | 12:34 PM
The point of me recommending larger cams, is so he could lower the boost and not sacrifice to much power so that he can safely run power on his stock block. Also to teach him a bit on turbo efficiency.
Old Aug 26, 2010 | 02:12 PM
andrewzaragoza's Avatar
if you are not on ecu controlled boost i suggest switching to that so that you could customize the boost curve. first off i wouldn't ramp it up all the way to 32 as that will bring too much torque. i suggest keeping watch of your torque and keep it close to 400. probably ramp the boost to say 28 and then slowly raise it to 30-32 as you go to the upper rpm ranges. that should keep your motor happy for a while and still have a good high hp #.
Old Aug 26, 2010 | 02:32 PM
4doorstreetbike's Avatar
Its a black not a stock turbo this turbo wakes up at 30 psi so at 32 psi your more then fine.The torque usually goes up when the boost passes the 31 psi level it's cause of the stock frame housing..
ridenrunwv
Sep 19, 2015 06:42 PM
tim85851
31
Oct 12, 2011 02:51 PM
HornstarBU
Lancer Aftermarket Forced Induction Tech
Feb 28, 2011 06:06 PM
tigerkill2007
Mar 17, 2010 07:06 PM
redevo8driver
Oct 7, 2004 04:03 PM
