400whp FP White Dyno on 93 (The Shop CT)
Thank you all
2.0 built block
wiiseco hd1400
Carrillo rods with Carr rod bolts
Acl everything bearings
Arp main studs
Arp l19 head studs
O-ringed unported stock head
Supertech dual springs and retainers
Cosworth m2 cams
Stock unported intake manifold
Stock unported throttle body
Stock unported exhaust manifold
FP White with 18psi wg
MR o2 housing
Cobb downpipe
UR test pipe
Invidia g200 catback
780cc injectors
Shepherd tranny
Act clutch
For the most part that's it... I will post a VDR from my previous turbo comparing the FP white... Completely different cars, each setup for a completely different purpose...
2.0 built block
wiiseco hd1400
Arp main studs
Arp l19 head studs
Cosworth m2 cams
MR o2 housing
Cobb downpipe
UR test pipe
780cc injectors
Shepherd tranny
Act clutch
Most probably yes.
I still have the drag radials on the car, so I will probably race it on the stock appearing class... Every opportunity to spank a couple of subarus is good!
chetrickerman
Aug 23, 2017 07:22 PM
kouzman
Jan 31, 2010 05:46 AM
