Force-Fed Tuned!! 6262&5857 Pump Gas Azz Kickers
I wouldn't use a spiky chart like that to quote any numbers, that's awful looking. You can tell in the video that the power is surging by the sound and the way the car is wobbling on the dyno
http://www.youtube.com/watch?feature...&v=orlthaF915U
Thank God someone i
Thank God someone i
The reason its so spiky is because the boost controller from what im told was causing it. Theres still alot of issues that need to be worked out with the car before it can go back on the dyno.
Boost controller dont do that the tune its self does it maybe your s.d is not tuned right not everyone can tune it.Wheres the graph??is this the first time the car has been tuned with this setup with babies or Bobby what ever his name is.??
actually I've seen the Greddy Profec B Spec II mess up if the duty cycle or gain is set too high. The boost will surge up and down if it's not setup properly. Regardless, posting a dyno chart like that with crazy spikes and 0 smoothing to boast about the number....they should be ashamed.
Hope you get your issues figured out and the car running properly. Looks like a nice setup
