Evo8 upgrading Evo9 turbo
Old Oct 27, 2010 | 04:14 PM
EvoJoeIX's Avatar
i mean i have a evo 9 turbo on my evo 9
car made like 390whp on cbrds dyno @ 28 psi (not pump gas)
i feel like the car is slow, but thats just me
dude can do whatever he wants, im just saying the evo 9 turbo is gonna run out of fun especially on pump gas. i like going fast, i understand everyone isnt into that. but even if you save the money and get an hta green, it leaves your option door a lot wider open then a stocker
Old Oct 27, 2010 | 04:23 PM
fqjdmct9a's Avatar
Originally Posted by Thoe99
350 on a hot day will make me satisfied, but if there's more to be had...that's icing on the cake for me. Later down the road, I can sell the 9 turbo and make back most of the money and then upgrade to a bigger turbo, or I can just completely convert to E85 and continue pushing it. I've thought some of it out
It seems your kinda of undecided i thought you only wanted pump gas but if you want to go e85 then just get a the 9 turbo and call it a day!
what part of orlando do you live in?
Old Oct 27, 2010 | 04:36 PM
pupo's Avatar
Just look on this forum and you will see a lot of people making decent power with a 9 turbo, for the money, I think it would be a good upgrade, you can up the boost and make power, I seen people making close to 400WHP with a 9 turbo. I have a 2005 evo 8 and have the 10.5 hotside turbo and I am also considering getting a 9 turbo. When you get to a certain point power gets expensive.
Old Oct 27, 2010 | 04:39 PM
EvoJoeIX's Avatar
you will never see 400whp on a evo 9 turbo on pump gas.... unless your on a high reading dyno
Old Oct 27, 2010 | 05:04 PM
Thoe99's Avatar
For now I wanna stay on pump93. I'll go E85 when we get more gas stations around here that doesn't make me drive 20 miles each way.
I'm in Maitland, you?
Old Oct 27, 2010 | 05:12 PM
fqjdmct9a's Avatar
Fl mall area.
I doubt we will get more E85 gas stations around here the only one is on the turnpike at turkey lake plaza. I would hope they get more but i doubt it at the time. You should just get the evo 9 turbo if thats what you really want i was just giving my opinion if you wanted even more power later on.
Old Oct 27, 2010 | 07:53 PM
mrdevo's Avatar
If you are installing it yourself, I'd say go ahead and try the 9 turbo, you'll see 10-20 whp if you have a 10.5h already. If you are getting it installed, do it right the first time with room to grow. I'd suggest a green at the bare minimum because they've been proven to run very well, even the first greens that came out.
Old Oct 27, 2010 | 08:23 PM
noypiC50's Avatar
Stories like this make me excited to get the 9 turbo again Any chance you have any dyno sheets I can compare with, esp on the low-end? ie: I look at my chart, at 3000rpms, I make about 100hp, at 3500 I make 175hp. Is yours the same or better?
Here is a dyno sheet comparison of the evo9 vs evo8(9.8 hotside). Only changes made between the runs are evo9 turbo (ported hotside) and 1200cc injectors (preparing for e85). 2nd Graph is the boost plot, as you can see the evo9 boost plot was done in lower boost also.All runs on 91 octane.
Attached Thumbnails Evo8 upgrading Evo9 turbo-scan0050.jpg   Evo8 upgrading Evo9 turbo-scan0051.jpg
Old Oct 27, 2010 | 09:01 PM
noypiC50's Avatar
Originally Posted by Novaspyder
I agree. I have about every bolt on possible and am only at a little over 360.
Stop spreading misinformation. 400whp has been done before on 93oct pump gas. Look here.
https://www.evolutionm.net/forums/ev...-purposes.html
Old Oct 27, 2010 | 09:06 PM
Thoe99's Avatar
Thanks for the charts. Were you fully tuned before and after?
Old Oct 27, 2010 | 09:14 PM
noypiC50's Avatar
Yes fully tuned for all runs. They were not done same day but weather conditions were basically the same.
Old Oct 27, 2010 | 09:54 PM
wshihdnevo's Avatar
Just get the IX turbo. Every car, depending on mods and what not will make different #'s, but you will for sure make 350 on a hot day if you have the right supporting mods. I made 385 on a 80+ degree day on my VIII.
Old Oct 27, 2010 | 10:03 PM
dRiFtInG_mR's Avatar
if u like autocrossing, it be nice if you had a hta green / white not gonna worry about spooling
Old Oct 27, 2010 | 10:30 PM
wshihdnevo's Avatar
And spend an extra $1300 in the process.
Old Oct 28, 2010 | 06:28 AM
fqjdmct9a's Avatar
400 is possible to do on pump gas but its been pretty hard to achieve. Only a couple of pleople have been able to to it.
Depeding on what he really wants for the car it could be worth it as same as it could just be a waste of money. If thats something that he wants and would be happy with it then he should just go ahead and get the 9 turbo, if he doesnt care about any room to grow in the future!
