Evo8 upgrading Evo9 turbo
Old Apr 28, 2011 | 01:55 PM
  #61
Srr's Avatar
Srr
my 03 evo 8 came with a evo 9 turbo... i love it
Old Apr 28, 2011 | 04:57 PM
  #62
fqjdmct9a's Avatar
we all knew you would end up wanting more power, It happens to all of us lol
Old Apr 28, 2011 | 08:26 PM
  #63
Thoe99's Avatar
The 9 turbo is great for my applications. In fact, I don't need more power for the autocross venue I go to. But then I went to the quarter mile drags and felt power hungry, thinking of easier ways to hit 11s. I chose the BBK Full because a lot of people are reporting stock-like spool and power down low (which is great for autox) and a higher efficiency range. Some are running 30+ psi and the boost only falls to about 26psi at redline. So basically, I keep my power down low, but have much much greater potential for high hp.
I still have the 9 turbo installed on the car. I currently run 24psi, but I'll probably push it to 26psi in the next couple weeks just to see how it responds.
Old May 1, 2011 | 12:05 AM
  #64
steelfire19's Avatar
I am wanting to buy a 9 turbo as well, this thread helps a lot.
Old May 1, 2011 | 08:34 AM
  #65
evo8john's Avatar
you probably wont see enough increase to make it actually worthwhile unless you plan on sending it in to get it upgraded in the future. You can clear 400 whp and 11's on a 10.5 hotside 8 turbo easy.
Old May 1, 2011 | 03:31 PM
  #66
akuma83's Avatar
I swapped my evo8 turbo for evo9 turbo and have great numbers. I made 347whp on pump gas on 26 psi mods: injen intake, injen upper and lower pipes and intercooler, GSC S2 cams, hks exhaust. also stock injectors. upgrading those to 1000cc soon.
Old Nov 25, 2017 | 06:37 PM
  #67
AustEvo's Avatar
This thread helped a lot, got an evo 9 turbo to install, just wanted to know what I could expect, and what I'd need to properly install.
Old Nov 25, 2017 | 06:57 PM
  #68
Bhsj13's Avatar
about 20-40whp over what you are making now on. this depends on fuel, boost, timing. I make around 340whp pump DJ with my stock 8 turbo, i would expect 365ish whp on same dyno with the turbo being the only change.
Evo8life
30
Jan 5, 2018 09:30 AM
GST Motorsports
32
Dec 24, 2017 10:16 PM
tscompusa
Sep 14, 2017 10:12 PM
b boy
Apr 13, 2017 09:12 AM
03lances
Lancer Aftermarket Forced Induction Tech
1861
Mar 14, 2016 10:30 PM
