We just finished doing a back to back dyno test on Skunks 68mm billet throttle body. We were impressed with the results. Average of 8-12hp and peak 10 ft.lbs of torque. Stay tuned as mak-speed.com will be doing a dyno test on Skunks intake manifold for the 4G63.
http://picasaweb.google.com/MAKSPEED...02230577008770
This motor is a last minute rebuilt for SEMA stock motor. It's a GT40 non bb that was meant for a 2.4 motor that we fried with a bad injector. The 2.4 motor is making 130hp more at 4600 RPMs-
It retails for $380 and as far as tuning goes we didn't touch the fueling even though we did notice our AFRs lean out about -.2 to -.4 at some areas. Keep in mind we are running an Autronic system w speed density so for factory MAF should take care of fuel compensation on the increase of air flow.
The test was against a stock throttle body.
Ill take the tried and true Buschur Ported 65mm.. Making proven power to 900whp.. Simple, cheaper, proven..
Quote:
Proven yes cheaper no cause you have to provide a core charge.Originally Posted by AWD Motorsports
To the op person can you post some pics on it??
Our cars come with a stock TB on it.. So unless you lost yours its cheaper.. The core charge is 100% refunded if you dont send yours 1st.. Originally Posted by EVO IXMR
Proven yes cheaper no cause you have to provide a core charge.To the op person can you post some pics on it??
Mike
Also did they ever resolve these issues.. The last i heard the TB wasnt up to par..
https://www.evolutionm.net/forums/se...body-junk.html
Dont know how long ago that thread (JUNK) was but everything worked fine for us and we just finished this last week. Maybe Skunk has done their homework on the problems. Every company goes through problems especially when they're the first to design-prototype a new product..then everyone else just copies it
Oh we did encounter one problem, the throttle cable bracket is touching the fuel line on a Perrin fuel rail because of the angle - so you need to shave part of it or get the another fuel rail.
Here's some pics--
http://picasaweb.google.com/MAKSPEED...SkunkProducts#
Oh we did encounter one problem, the throttle cable bracket is touching the fuel line on a Perrin fuel rail because of the angle - so you need to shave part of it or get the another fuel rail.Here's some pics--
Did you guys *actually* do a boost leak test to see if the seals held pressure? This was the big issue with the one we had locally on Kracka's car, even the new seals they sent were junkity junk.
Also I don't see a boost plot overlay, that would be helpful in knowing where the gains came from
looks like it was used with the skunk 2 intake manifold also.. so it is known to perform when using that intake manifold according to another test by a vendor on here. with that said ill never go near skunk2 parts for my evo ever.
Quote:
No Skunk Intake manifold yet..we will try to install that this week and see what improvements it makes. As far as boost leak goes, here is a graph with data and the boost stayed the same for both runs.Originally Posted by tscompusa
looks like it was used with the skunk 2 intake manifold also.. so it is known to perform when using that intake manifold according to another test by a vendor on here. with that said ill never go near skunk2 parts for a evo ever.
http://picasaweb.google.com/MAKSPEED...02249489179826
well maybe its revised then. i think they made multiple revisions of the intake manifold also, so it makes sense that it would be revised. skunk2 seems to offer good things to the honda world, but not so much to the mitsubishi.Originally Posted by makspeed
No Skunk Intake manifold yet..we will try to install that this week and see what improvements it makes. As far as boost leak goes, here is a graph with data and the boost stayed the same for both runs.http://picasaweb.google.com/MAKSPEED...02249489179826
it does look like a very nice piece tho for sure. you should compare it on dyno with ported stocker though.. if it makes signficant power over a ported stocker it would sell like wildfire on here if its a direct bolt on.
in the Honda world, you can market almost any crap to them and they'll buy it.
