FP Black powered Evo IX 27PSI 93OCT
Old Feb 18, 2011 | 08:10 PM
  #31
nonschlont's Avatar
congrats to the OP!
Old Feb 19, 2011 | 08:13 PM
  #32
mchristian's Avatar
thanks for all the comments guys! The FP Black is an amazing turbo (even on pump gas) with the right combo and tune. I'm not a competitive autocrosser so not concerned with the decrease in spool...the additional 100hp up top right now is more fun than the stock turbo and when its time for the 2.3 or 2.4 and better fuel I should be near 650+ w/my setup on high boost.
Old Feb 19, 2011 | 08:41 PM
  #33
anthonyrb98's Avatar
nice numbers. i wonder at what rpm a black will hit full boost on a stroker or a 2.4.
Old Feb 20, 2011 | 12:29 AM
  #34
xRoguex's Avatar
another 93 black car.. bet its a fun whip
Old Feb 20, 2011 | 10:36 AM
  #35
tscompusa2's Avatar
my 2.3 does 32psi by 3800rpm, so you're looking at around 36psi by say 4200rpm and peak torque by 4400-4500rpm. extremely fun setup for sure. (this is on a map ported exhaust manifold, br stage 3 head)
ya and you need to fix yours so i can finish your tune.
Old Feb 20, 2011 | 12:20 PM
  #36
Cali 18's Avatar
Good numbers!
Old Mar 8, 2011 | 08:37 PM
  #37
ajstefanacci's Avatar
Can't wait to see what mine does once you tune it
Old Mar 10, 2011 | 08:06 AM
  #38
dabeast's Avatar
nice numbers. should be pretty fun on the street
Old Mar 10, 2011 | 02:25 PM
  #39
mchristian's Avatar
The tune is much cleaner... smoother driving and yea the power is neck snapping compared to where I was a few months ago. This tune has made a new set of tires a priority...I'm spinning in 1st and 2nd now.
Old Mar 15, 2011 | 09:50 AM
  #40
MRfastMR's Avatar
everyone ripped on me when i made 463/444 on fp black and 93 pump @ 29psi.....you get nothing but nice things said.....
Old Mar 15, 2011 | 07:57 PM
  #41
mchristian's Avatar
Those are great numbers for the black snail on 93!
I've noticed there are some Forced Performance haters lurking and thats likely who is trash talking?
FP has a good thing going and selling what a lot of us want...reliable, inexpensive, stock appearing turbo option that makes good power!
Old Mar 31, 2011 | 08:59 PM
  #42
spyderx's Avatar
vrsf, I am thinking about maybe FP green on 93 but tempted to go red or even black. It'll be for street driving on stock bottom and it has 150k miles. Runs great w/ stock IX turbo. Just that I wish it had bit more. I'll eventually build the bottom end. Knowing the upgrade for turbos are about same cost...which would you recommend?
Does 84mm port improve reduce lag? I had FP red w/ 64mm cover on another evo and found it to be laggy for street... Just tempted again... lol thx
Old Apr 1, 2011 | 12:27 AM
  #43
tscompusa2's Avatar
it all depends on what you want.. a bigger laggier turbo is actually safer on stock internals since it delays torque/peak boost.
fp green will spool like a stock 9 turbo
the 84mm surge ports are to reduce compressor surge of the turbo, and should be used imo.. plus makes a cool whistle noise also.
based on what you said, id recommend a fp green hta to you since you dont like lag.
how much more HP are you talking ? whats it at now? you might be satisfied with what the stock evo 9 can produce with supporting mods.
Old Apr 1, 2011 | 10:09 AM
  #44
spyderx's Avatar
S1 cams, RC1000 with stock 9 at 23psi 350/350. Wouldn't mind 450/400 on 93 with stock motor... Thanks
Old Apr 1, 2011 | 12:09 PM
  #45
zeus1's Avatar
that would be a fun car.. curious why you are running relatively low boost now? think there are some cars on here that have made 450 (virtual dyno) on an hta green but run more boost and perhaps e85 to get there but search around.. what dyno was your current350/350 made on?
