FP White dyno info English Racing
#48
exactly, I spoke to robert personally about my situation when I was needing a rebuild. He said that the white could be done for 675, or the 71 for 600. My exhaust wheel was clipped on my white. Turbojunkie, is your exhaust wheel clipped/modified? They are most likely trying to phase the white out in favor of the comparable 71hta.
#49
#51
What does the equate to flow-wise? By "backside" are you referring to the hotside?
With all of the options available on the MAP portal, the EF2 would be similarly priced as the 73HTA Green.
How can I take a look at the 71HTA if it is not listed on the Force Performance portal? It looks like it could be a great in-between for me and my goals.
#52
How can I take a look at the 71HTA if it is not listed on the Force Performance portal? It looks like it could be a great in-between for me and my goals.[/QUOTE]
You will love the fp white, Im enjoying my car now rather then when it had the 6262 on it.
#54
I found the information hidden on the FP portal. Since I have an VIII, I did some price comparisons on buying a used IX turbo, shipping to FP, charges for studs and threads that need to be repaired, possible new housing, porting, and the 25PSI wastegate actuator and it would be easier if I just bought a 73HTA Green brand new.
JohnBradley
Oct 6, 2015 02:45 PM
