Sonny's 2.3L 633whp FP Red Single Scroll C16
Old Sep 22, 2015 | 11:14 AM
JohnBradley's Avatar
First, I need to apologize for not getting this new thread done sooner to help clear up confusion on the last one.
Sonny had made 467 on S1s and c16 on a stock 2.0L after evolving his car over the course of a year or so. Eventually there was an oil pump failure and it was necessary to do a built motor. The choice was made to do a 2.3 to keep his original block, get the best headgasket sealing we could, and keep the price reasonable.
Mods -
SD tune
ER2.3 build 2.0 w/100mm crank- all options, oringed, er oil gear, kiggly HLA etc
Bushmaster Stage 3 race port with 1mm oversize valves
GSR springs, gsc lifters
R2 Cams
Magnus Intake Manifold
buschur ported stock TB
1250 FIC injectors
AMS oil Pan
Eagle Crank
Full-Race Turbo Manifold
FP RED turbo with single scroll stainless housing
Tial WG
Tomei titanium exhaust
busher lower intake pipe
ETS upper
buschur catch can
buschur intercooler
ER built downpipe and open dump for SS housing.
jacks tranny, jacks tcase
os giken twin disc
kw coilovers
carbon fiber driveline
curt brown ceramic wheel bearings
Dyno sheet -
This car is still a monster, makes great power on the daily, and with one or 2 small mods I think could make more. As far as more power on C16 there may even be a little left there though I am thinking not much. One thing that I am very pleased with is that it makes almost as much on WA 89 (cali 91) as it used to make on C16 on the stock motor and small cams.
Aaron
Old Sep 22, 2015 | 11:20 AM
06MREvo's Avatar
That is awesome. I had Mr. Brown build me a 2.3 long block, which will be using R2 cams & an FP Zephyr.
Are these the cast or billet R2 cams? Any benefit to using the billet over cast?
Old Sep 22, 2015 | 11:24 AM
These are cast. There were numerous reasons to switch to the billets and one is production tolerances are even closer than they used to be. The cam grinding equipment has always been CNC but there is more ability to adjust the lobes than there used to be. I feel that its not going to make any difference in power though.
Old Sep 22, 2015 | 11:26 AM
boxerdropper's Avatar
That spool up is great for the single scroll!!!!
Old Sep 22, 2015 | 03:06 PM
Being a 2.3L definitely helps.
Old Sep 22, 2015 | 05:32 PM
Erik@MIL.SPEC's Avatar
This graph/car interests me since I will have an MHI Red on a 2.3 and E85. Interested to see differences in spool up and curves...especially with open scroll vs. twin (our mods are a little different though)...
Old Sep 29, 2015 | 08:53 AM
mrfred's Avatar
definitely some ***-kicking power. would love to drive that evo to get a feel for transient response. i'm also curious about that clutch. noisy? easy engagement?
interesting choice of injectors considering all the high-end parts.
i'm wondering what you'd change to make more power. if the full-race manifold has 1.25" runners, i could see swapping that for 1.5" runners. maybe fic1050sp injectors if e85 is not in the cards? 65 or 70 mm throttle body?
Old Sep 29, 2015 | 09:48 AM
LetsGetThisDone's Avatar
It already has 1250 injectors.
I think the buschur ported TB is 65mm..
Old Sep 29, 2015 | 10:06 AM
mrfred's Avatar
I was assuming that the 1250s are the older low-Z that leave a bit to be desired for consistency.
ok.
Old Sep 29, 2015 | 10:14 AM
e_kobz's Avatar
Awesome setup. Bet it is an animal on the street
Old Sep 29, 2015 | 10:43 AM
lancerrally45's Avatar
Could you expand on this subject?
Old Sep 29, 2015 | 10:54 AM
mrfred's Avatar
Its just that they are not the best for low pulsewidth conditions, i.e., at idle and cruise. Its a little tougher to get consistent idle and closed loop cruise trims. Injectors have come a long ways in the last 5 years, and while at one time the older low-Z technology would have been considered very good, now they are more middle-of-the road with the high-Z options generally performing much more consistently at low pulsewidth. Price for high-Z is much higher though as well. But let's not get off-topic.
Old Sep 29, 2015 | 01:09 PM
AdamAndEvo's Avatar
Correct its 65mm TB
the injectors are left over from when i just put the red on the stock motor, they seem to be doing the job.. Idle and Cruise are great.
The R2's in a parking lot took some time to adjust to.
e85 is not an option, i have no pumps even remotely close to me.
Meth is next to help this pump gas get some life.
twin disc is loud as hell, annoying to drive, decel noise sounds like ****s broken and it engages like an on/off switch.. Hooks great though and its lasted 12k miles so far.
Old Sep 29, 2015 | 01:52 PM
e_kobz's Avatar
What's the compression ratio of the piston? 9.0:1?
Old Sep 29, 2015 | 02:29 PM
Probably 9:1 since the car was intended to run and make decent power on pump gas.
