800WHP Force-Fed Performance "Reaper"
Old May 3, 2011 | 08:56 AM
  #106
tweaker41's Avatar
As long as he doesn't trap higher in the 1/8 then the 1/4 ill be happy. Haha
Old May 4, 2011 | 07:09 AM
  #107
HIS Motorsports's Avatar
Originally Posted by Force-Fed Performance
Babi was a comedian in Puerto Rico I guess. We will see, should be interesting for sure.
Old May 4, 2011 | 12:41 PM
  #108
Force-Fed Performance's Avatar
Build thread will get made tonight for the car with pictures.
Old May 4, 2011 | 06:05 PM
  #109
DouglasAutoworks's Avatar
Alternator reached us and I had it tested at our rebuild shop which tested out fine. Justin- I would suggest going through your wiring since the stock unit you put on afterwards also quit working. Please update what you find. Thanks- Mike Witt at DouglasAutoworks
Old May 4, 2011 | 11:02 PM
  #110
d613's Avatar
wow ! great job, and an amazing car!
Old May 5, 2011 | 12:49 AM
  #111
redleg225's Avatar
As long as nothing breaks it's all good!
Old May 8, 2011 | 04:24 AM
  #112
RaysEvoX's Avatar
Any update on this Justin and Babi
Old May 9, 2011 | 11:24 AM
  #113
just trying to get around to it Ray.
For now we did make a build thread that will be updated showing progress
https://www.evolutionm.net/forums/ev...per-build.html
Old May 9, 2011 | 11:51 AM
  #114
06MREvo's Avatar
Originally Posted by crewdawg130
12flat at 150mph. Lololololol with A 2.0 60'....
haha...maybe 11.5!
Old May 10, 2011 | 09:12 AM
  #115
kingkong's Avatar
That turbo is massive!!
Old May 17, 2011 | 09:13 AM
  #116
Should be back on the dyno this weekend
Old May 23, 2011 | 06:31 PM
  #117
jyoung's Avatar
****s serious !
Old May 23, 2011 | 11:36 PM
  #118
sparky's Avatar
....We originally had the haltech controlling the speed controller by itself, then we had a problem with the fuel pump and had it sent back to fuelab to be checked. It had a bad part on the board and was causing the pump to bind up. Never had a issue with cavitation or starvation. So when the pump returned instead of controlling it with the haltech we installed the resistor that comes with the pump to operate the controller much like a hobbs switch would a twin system. While the car is idling and out of boost the pump would run at constant low speed. Then at a specified boost/rpm the haltech triggers the controller to high speed. We think we have one of the DPO's wrong and the pump isnt even switching to high speed since with it in aux fuel pump mode you cannot see the hz of it like when you have it in Generic duty cycle. So we are going back to that setup and making sure the pump is running 100%
Keep us posted please!
Old May 24, 2011 | 05:45 AM
  #119
Def will. Just getting time to get around to it is whats tough. Smoked the triple carbon already so will either go back in with met discs or may be working with Comp Clutch on their new twin setups coming out.
Old May 24, 2011 | 11:56 AM
  #120
project_skyline's Avatar
I think you seriously need the tilton triple carbon lol.
