Evo 8 Evo9 Turbo Cam Gears E85 -- Results
Old Jul 23, 2011, 08:49 AM
evo8426's Avatar
What about advancing/retarding the gear differently? Such as -2/0, ect...
Old Jul 23, 2011, 08:58 AM
TheBoz's Avatar
Ya I am going to be doing some of that today. I just ran out of time. The hard part is that I really need to do all the tests again to make them valid. Also when I start the testing this time, I am going to do 2 back to back baseline pulls to ensure that they are the same.
Here is what I am going to retest this weekend.
0/0
0/+2
0/-2
+2/0
-2/0
+2/+2
-2/-2
-4/-4
I will not make any Timing/AFR/Boost changes from test to test.
Old Jul 23, 2011, 09:00 AM
tscompusa2's Avatar
Old Jul 23, 2011, 09:16 AM
tscompusa2's Avatar
Originally Posted by novem
Wow...nice. You're hitting almost 30psi on stock headstuds, what Psi is safe to run before you need to use aftermarket?
N
i ran up to 35psi on stock studs with stock block and fp red. the stock mitsu seal is pretty good.. but the thing is they arent studs stock.. they are bolts.
whenever you have the head off i highly recommend the arp hardware though, and also you could do the 1+1 but if its not done right then it can potentially cause problems with the head seal.
Old Jul 23, 2011, 09:28 AM
Babi@Force-Fed's Avatar
0/0
0/+2
0/-2
+2/0
-2/0
+2/+2
-2/-2
-4/-4
lookin fwd for this
Old Jul 23, 2011, 04:43 PM
novem's Avatar
So 30 psi and below is safe on a stock head?
Old Jul 23, 2011, 05:18 PM
That's a trick question
Old Jul 23, 2011, 06:35 PM
evo8426's Avatar
Are you asking about the stock head bolts? I guess it depends on how comfortable you are with knowing it may or may not lift
But me personally I would not be comfortable.
Old Jul 23, 2011, 09:54 PM
novem's Avatar
Ya, that's what I'm asking..what psi is safe on stock head? 25psi..27? Some guys are running close to 30 and above, I'm guessing mid 20's?
N
Old Jul 23, 2011, 10:04 PM
evo8426's Avatar
It really depends on how safe the tune is, detonation is what causes the cylinder pressure to sky rocket and will lift the head. I didn't run over 26psi on stock head bolts on pump gas for a just in case it happened, there are people on this forum that won't run more than stock boost on the stock head bolts. Now that I have head studs I run 28-29psi on e85. But I think it really comes down to how comfortable someone is for how much they will run.
Old Jul 24, 2011, 04:01 AM
Alpha1's Avatar
good info......
Old Jul 24, 2011, 09:54 PM
TheBoz's Avatar
Sorry guys I got busy tuning a Series 2 AEM EMS over the weekend, I did not get a chance to redo my cam gear test.
Old Jul 24, 2011, 10:20 PM
project_skyline's Avatar
I see no reason to mess with settings past stock, holding more boost up top doesn't necessarily mean your going to make anymore power anyway. Regardless of what you change in the tune.
Nice testing though, guess we will see if you can find any other settings that work better then stock.
I wouldn't even consider doing ARP headstuds on stock turbo, the stock ones are freaking strong as hell.
Old Jul 25, 2011, 09:47 PM
VancouverEvo8MR's Avatar
i wanna see the dialing results of the cams.
Old Jul 28, 2011, 10:27 PM
TheBoz's Avatar
So I ran a few more tests tonight, and did my control test last. There was a net gain of 0. Myabe later in the week I will work on the Intake cam.
+ = When looking at cam gear rotate clockwise
- = when looking at cam gear rotate counter clockwise
Red = 0/+2
Blue = 0/-2
Green = 0/0
Attached Thumbnails Evo 8 Evo9 Turbo Cam Gears E85 -- Results-dyno.jpg   Evo 8 Evo9 Turbo Cam Gears E85 -- Results-dynodj.jpg
TheBoz
Sep 16, 2011 03:17 PM
Dynotech Tuning
Apr 2, 2011 10:15 AM
ArchieBabes
Aug 18, 2010 09:24 AM
vegasboy301
May 11, 2006 07:38 PM
vegasboy301
Jul 26, 2005 02:05 AM
Quick Reply: Evo 8 Evo9 Turbo Cam Gears E85 -- Results
