Precision T3 67/65 - 2.0 - 900hp!!
Check it out --->https://www.evolutionm.net/forums/dr...40-152mph.html
Check this out guys ---->https://www.evolutionm.net/forums/mi...-modified.html
Just wondering, it looks like you're still making plenty of power at 9k. You obviously aren't going to make any higher peak after that so there's no point just to post a dyno number, but I'd be interested to see how far your power curve goes. Are you taking it higher at the track?
Evoboss - Thank you sir. You should definitely see 800 hp on your set up! Keep us posted.
The 67/66 will get the job done but you should consider a different cam set up.
Anubis - Thanks!
Mitsael - Thanks bud! Stay tuned for our next set up.
-Cisco
The 67/66 will get the job done but you should consider a different cam set up. Anubis - Thanks!
-Cisco
