E85 vs 93oct
Old Aug 27, 2011 | 12:31 PM
Thoe99's Avatar
E85 vs 93oct
Here's a test case showing the power gains I unlocked just switching to E85 and redoing the tune, all other mods being equal (24psi on both tests).
Mods are:
BBK-Full ported @24psi
GSC S1 cams
QTP 3" downpipe dump exhaust
ETS 3˝" intercooler
ported/coated exhaust manifold & Megan o2 housing
Vibrant cone air filter
Nisei licp
PTE 1000cc injectors
Walbro 255 fuel pump
421hp / 361tq
That's +43hp +29tq (about 11% peak gain)
Old Aug 27, 2011 | 12:38 PM
Jim in Tucson's Avatar
This is very revealing. Exactly the kind of test I like to see - apples to apples.
Old Aug 27, 2011 | 12:55 PM
E-Spec@Tach Motor Works's Avatar
+1 ,,, nice test!
Old Aug 27, 2011 | 01:00 PM
Ian0611's Avatar
Good stuff! You could probably turn up the boost a little more on the E85 and get even more out of it.
Old Aug 27, 2011 | 01:02 PM
Thoe99's Avatar
Yea, I know I can. I gotta test this at my autocross track to see if it's too explosive for how tight of a course we run. Otherwise, I may have to detune , or start attending bigger tracks .
Anyways, how much torque is the stock clutch rated for? I'm still on it, haha.
Old Aug 27, 2011 | 01:08 PM
zeus1's Avatar
good comparison. can you post your results using the below VD?
http://www.bradbarnhill.com/projects/VirtualDyno/
Old Aug 27, 2011 | 01:23 PM
Thoe99's Avatar
I use both of these dyno programs when I tune, however, I prefer DLL in some ways. I'm not fully convinced on VD's accuracy. For instance, VD's 5250rpm crossover point isn't even the same on both lines here. Also, when I chart graphs in excel using the raw data logs, the boost plots at spoolup are much smoother looking than VD's.
Old Aug 27, 2011 | 02:17 PM
Acree's Avatar
It looks like you could stand to add a degree or two of timing from 3000 to 3400. Maybe interpolate?
Very nice results!
-Acree
Old Aug 27, 2011 | 06:25 PM
mt057's Avatar
1.08 was my least favorite version of VD. The new ones are outstanding though.
Old Aug 27, 2011 | 07:57 PM
Thoe99's Avatar
I don't know. I just downloaded the new version and boost still looks out of whack compared to a graph taken right out of the raw data log in excel (VD on left, excel on right):
Old Aug 27, 2011 | 09:07 PM
getsideways's Avatar
You mentioned stock clutch i have a local tuned at 430 WTQ 480whp he just made the change to E85 , and this was all the clutch would hold. It was fine around 400wtq 430whp .
Old Aug 27, 2011 | 10:27 PM
Boosted Tuning's Avatar
Did you unclick "Smooth Boost/AFR" in the options??
Gary@MellonRacing
Jan 31, 2015 08:00 PM
Gary@MellonRacing
Oct 1, 2012 09:48 AM
Gary@MellonRacing
Sep 9, 2011 04:40 AM
Gary@MellonRacing
Jun 24, 2011 02:59 PM
4g63girl
Jun 2, 2010 10:27 PM
