Testing the DBB Black
One of our customers, Daniel (Yahu), decided to upgrade his journal bearing black on pump/meth to the ball bearing black.
While I wasnt expecting to see any more peak power since nothing really has changed, I was curious to see how much the response differed. On the street I must admit to not really feeling much of a difference. Then again I was running the car at 29.9psi where during the test I had it 24.
Brief description of the test process-
Bring car up to temp (176*) and accelerate to 3700 rpm, coast down in high vacuum, and then stuff it at 2700 to see how fast it responds. In this test I got clean run after clean run but had issues synching the starting rpm and the one time I did it phantom knocked in the mid range. The results still speak for themselves.
Mod list-
Evo IX
ER SR2.4
Bushmaster ported IX head
GSC S2 camshafts
Magnus V5 cast intake manifold
ER SD tune with Omnipower 4 bar
FIC 950s
AEM meth kit
255 LPH
3" Buschur TBE
etc.
Mod list-
Evo IX
ER SR2.4
GSC S2 camshafts
FIC 950s
AEM meth kit
255 LPH
3" Buschur TBE
etc.
You can see that clearly at the bottom of the sheet.
Now since i cant see the color differences between the 2 graphs
which turbo made better power @ 3500 & 7500 rpm?
any idea if the original fp-blk had the same spec turbine wheel as the DBB unit?
I recall people stating that some turbine wheels were cut back more than others with regards to the fp-blk...
Nice compare btw
can the owner of the car enlighten us by describing the transient city driving response / romp sessions between the 2 turbos?
Nice compare btw
Nice compare btw
Nice compare btw
aaron
dont know why these threads get posted?
quite simply the BB center is NOT responsible for the gains seen here.
the average consumer just will simply believe the BB black makes more power because of threads like this.
