Built 2.0, FP Black, 93 Oct. CBRD Tuned ;)
Thanks alot guys! Finally made the club
Todd6027 - Its at a 12.2 + AFR for less then .4 seconds on a 3rd gear pull. Also you have to take the car, fuel and timing into consideration. Every car is different
Mauricio - Thanks man, 60ft's were 1.6x the whole day. No taper, it actually creeps a hair on the top end
3 port grimmspeed, 25 psi FP wastegate actuator, V7, JM Fab o2 dump =
No spike, no taper
Curtis = 11.3x street tires, 10.9x slicks on 17" rims w/stock brakes ect, just swapped them out
No spike, no taperCurtis = 11.3x street tires, 10.9x slicks on 17" rims w/stock brakes ect, just swapped them out
ya a 3 port you can hold a razor solid line across the board.. i kind of miss my grimmspeed at higher rpm.. but not downlow.. i may give it another try downlow and do some back to back testing on it. the only reason i removed it, was cause i lost lots of feeling in tq downlow & i like to play with boost often.. it transformed the car into smooth vs yank feeling.. could be just the afr change though. im kind of spoiled with the hallman sticking out of the cig hole to be honest. if i ever wanted bragging rights tho the 3 port is the way to go.. cause you dont have to run high boost to hold it uptop. so 33 with a 3 port would be somewhere around 40 on a mbc taper with a normal preloaded wga.
if you play with preload on the fp 25psi wga though, you can make it hold 31 across the board with no mbc/3port at all controllably.
Spec-OpsMotorsports
Aug 27, 2015 05:04 AM
FS[Northeast]: 2006 IX RS WW w/21k miles
michaelrc51
For Sale - Cars For Sale
37
Aug 11, 2015 10:57 AM
tscompusa
May 12, 2015 08:23 AM
boosted91t
Nov 29, 2011 07:44 AM
