My E85 evo, Virtual Dyno #s vs. real Dyno #s
Old Dec 4, 2011 | 11:56 AM
Nelson999's Avatar
so i had the chance to do a pull with my car yesterday hooked up to Virtual Dyno. this is about 2 weeks after the real Dyno tune was done. the temperature was almost the same on both days. so here are the results.
car: 2005 Evo MR, Stock Turbo, Stock Cams
cobb intake
Works Downpipe
RRE test pipe
HKS carbon TI catback
TurboXS FMIC
ETS LICP
PTE 1000cc injectors
walbro 255 fuel pump
crushed IX DV
peak boost of 29psi
virtualdyno in DynoJet mode, 405hp/405tq
virtualdyno in Mustang dyno mode, 353hp/353tq
and the Dyno sheet from my tuning session at FFtec on the Mustang dyno, 355hp/350tq
only a 2WHP difference on virtual mustang and the real mustang! i do have 18" volks on the car now, and had stock BBS when the car was on the real Dyno
Old Dec 4, 2011 | 12:04 PM
zeus1's Avatar
more to back up the virtual dyno thanks for posting up.
Old Dec 4, 2011 | 12:07 PM
Nelson999's Avatar
ya exactly, figured id post up for the VirtualDyno doubters
Old Dec 4, 2011 | 12:15 PM
getsideways's Avatar
Good Job once again VD proves to be scarily accurate, it appears on the mustang dyno comparison it makes power slightly earlier on the real dyno around 3500RPM.
Did they make use of the dyno brake, and comparison was in 3rd correct?
Old Dec 4, 2011 | 12:27 PM
97EagleAwd's Avatar
Awesome comparision and great info. How do you get files loaded into the program ?
Old Dec 4, 2011 | 12:28 PM
Boostevo58's Avatar
Now I feel alot better about my numbers.
Old Dec 4, 2011 | 12:32 PM
Nelson999's Avatar
whys that?
Old Dec 4, 2011 | 03:09 PM
tscompusa's Avatar
Originally Posted by Nelson999
whys that?
due to all the misinformed people on the forum he was prob brain washed the vd read high or something.. who knows. its the complete opposite for those who tested back to back.
Old Dec 4, 2011 | 03:57 PM
civicej8's Avatar
thats really amazing right there,!
Old Dec 4, 2011 | 05:31 PM
khasal's Avatar
Great to read OP. Thanks for the comparisons. That backs up my 404 whp on VD.
Old Dec 7, 2011 | 09:18 AM
jordan4g63's Avatar
Very good info thanks for the post. Thats pretty amazing
Old Dec 7, 2011 | 10:23 AM
blackenedwings's Avatar
Virtual Dyno does seem to be scarily accurate compared to real dyno numbers... its surprising actually considering the variance of conditions since I doubt I have a truly flat/straight road in my entire state.
Old Dec 7, 2011 | 01:58 PM
JDavenport's Avatar
My experience was about the same:
https://www.evolutionm.net/forums/ev...ing-limit.html
VD and the real dyno were very close. If you load accurate data into VD and do solid pulls on level ground, it just works. As an engineer that is an argument I have always made. Given controlled conditions, deriving power and torque from pull data is just math.
But as some have noted, the 'purists' and fanboys always want to nay-say the software approach.
Old Dec 7, 2011 | 05:37 PM
mikegsturbo's Avatar
I have a question what's up with getting pistons for this setup and cams with 10-1 pistons can you make more power with the stock 8 turbo and can you use the stock head gasket even is the block is decked ? Just wondering if there wold be a noticable difference compaired to this setup ??
Old Dec 7, 2011 | 09:25 PM
Rough_draft's Avatar
Nice job Nelson!!
