781hp @41lbs ...On E85 ...on a Mustang Dyno ...3rd gear pull.
Old Mar 21, 2012 | 07:35 AM
  #46
way2qik's Avatar
Originally Posted by browningderek
Another 11:1 compression user here. LOL Except mines not making that much power... What size is you turbo in mm? What was you injector duty cycle on those dyno runs? My injectors were around 90% when i made 735 also with twin 255"s. Are you sure your pumps are just tired? walboro's get that way quick. I only run them 2-3 years. I got a new set bout to go in right now. If you think they are good, the other culprit is your feed line as Emery suggested. Its a fairly cheep mod anyway. It couldnt hurt. I think i put mine together for less than $125 from summit with a fuel filter.
The turbo is a 68mm (inducer/inlet size) turbo. The exducer side is 98mm. It uses the BorgWarner ETT (extended tip technology) which makes it act like a bigger turbo. I believe this makes it the biggest turbo (both compressor and turbine wheels) you can get in a t-3 footprint. Yes, the wheels (both cold and hotside) are bigger than even a Precision 6766 or the new 8794 that everyone raves about, or even the 9180 that some have used.
Summary of Bullseye Comp68r turbo (the baddest, nastiest, t3 footprint turbo on the block
Compressor Wheel:
-Inducer...68mm
-exducer...98mm
Turbine Wheel
-Interior Wheel size...80mm
-Exterior Wheel size...71mm (can be made as large as a custom 74mm)
Injector duty was near 90%, but I am gong to re-scale them, and it was high because we were running out of fuel and the injector was trying to compensate somewhat. At the power level I think this thing will make at 44-45psi, I think I'll come close to maxing the DC on these id2000s. I really don't want to go to a double fuel rail set-up if I can avoid it.
I am going to upgrade the feed lines to the rail. I'm also looking at having Dave put at least one, maybe even two of those new Walbro 400 in my double-pumper setup. Even if two of them is overkill, I know I will have enough, and I like not having to worry about things like that.
For example, I have the Sparktech COP-CDI 14 box on my car. Most other guys have the CDI 12 box and do just fine with that box. It cost me a little more money, but I wanted the box that would burn raw alcohol if necessary. This way I don't have to worry about it
Old Mar 21, 2012 | 07:41 AM
  #47
phrequenc's Avatar
Very impressive!
Old Mar 21, 2012 | 07:42 AM
  #48
antilag_200's Avatar
Forward thinking is what delivers the results.. that is just plain old ridiculous, on that dyno.
well done
Old Mar 21, 2012 | 09:23 AM
  #49
JohnBradley's Avatar
Still working on the bulkhead fitting picture. Lunchtime probably.
Old Mar 21, 2012 | 12:30 PM
  #50
R/TErnie's Avatar
Old Mar 21, 2012 | 01:59 PM
  #51
anthonyrb98's Avatar
Originally Posted by tscompusa
whats funny is this mustang really reads low as hell.. Scott with 480whp on this mustang went 138mph in a almost full weight evo.
your car must be stupid fast.
just read this...if it's true, then your car must be insane. good stuff!
Old Mar 21, 2012 | 02:13 PM
  #52
Justin at STM's Avatar
Congrats on the numbers Dan! Car must be crazy!
-Justin
Old Mar 21, 2012 | 03:30 PM
  #53
n2oiroc's Avatar
here is a bulkhead for the return, not feed but you get the idea.
Old Mar 21, 2012 | 05:05 PM
  #54
Originally Posted by R/TErnie
Eric, that is exactly the one.
Thanks a ton
Aaron
Old Mar 21, 2012 | 05:56 PM
  #55
way2qik's Avatar
Its true. Call Speed Industry and ask them. Phone is on the dyno sheet
-Justin
Thanks a ton
Aaron
Thanks for your help and the pics, guys. Very helpful.
Old Mar 21, 2012 | 07:47 PM
  #56
R/TErnie's Avatar
I order all my AN stuff from www.anplumbing.com
great shop to do business with and I've been buying an plumbing from them for 10 years.
Old Mar 21, 2012 | 08:03 PM
  #57
SDevo13's Avatar
Where is this turbo seeing full boost?
Old Mar 22, 2012 | 05:48 AM
  #58
way2qik's Avatar
I started each pull at 3800rpm and I believe we were seeing it all in by about 5000rpm. But, I'm not absolutely certain on that, so let me check to make sure.
Last year the turbo was laggy with only 3inch downpipe and exhaust. Its much more responsive this year with the 4inch downpipe and exhaust.
Old Mar 22, 2012 | 09:12 AM
  #59
SDevo13's Avatar
I call a ride if you are making the shoot out this year lol.
I don't think I'll ever go bigger than a 6266, but if I did and that is hitting full spool at 5k I would have to strongly consider that turbo lol. The 6266 its actually overkill (even with the f'in hks 280s) for the tracks I'll be hitting up over the summer, but oh well ^_^
Old Mar 22, 2012 | 09:28 AM
  #60
way2qik's Avatar
I'm using an AEM electronic boost controller on the car. With this we can play with making the boost ramp agressive by hammering the wastegate closed earlier. This allows a more aggressive boost curve than what you would get with a manual boost controller. The advantage of a simple manual controller is that it is EASY...basically dummy proof. But if you can learn how to make an electronic controller like AEM work, it will allow you to make a bigger turbo like mine spool in ways you wouldn't expect.
