Confused evo 8 only 279hp!!
Old Sep 19, 2012 | 07:36 PM
Pssst's Avatar
Originally Posted by adolfo415
Is a dynojet!!
Ouch...
Definitely do a boost leak test, then compression test... Also 20psi? Thats nothing.... id crank it up to like 25... however going to 8k isnt gonna make your power higher
High_PSI's Avatar
Up the boost, at least 25PSI. Power is low should be 350+ with cams.
Old Sep 20, 2012 | 12:23 AM
Piro Fyre's Avatar
Yeah, you will need more boost if you want to surpass 300. 25 will get you a lot. With pretty much same mods (3" turbo back exhaust, AEM intake with cone filter, mystery cams that might be 272 of some sort, and a crappy tune by previous owner) I was around the 350 mark.
Old Sep 20, 2012 | 09:43 AM
adolfo415's Avatar
Can I pull 25psi from my evo 8 2005 stock turbo? Does 25psi in my stock engine will be safe?
Old Sep 20, 2012 | 09:58 AM
cdupont03's Avatar
You are barely above stock boost, and I have seen people run 30+ lbs on a stock motor. If there are no problems 23-25 on the VIII turbo and stock motor all day...
Old Sep 20, 2012 | 12:46 PM
HsamehH's Avatar
it's fine with safe tuning not just pushing it to 25 psi.
Old Sep 20, 2012 | 01:39 PM
deadstockkpomp's Avatar
i was going through this last month my car only made like absolutely no power on the mustang dyno. Turned out it needed a head rebuild, its now making close to 300 on a conservative tune. Id say rule out the stupid thing first, boost leak, compression test, other than that it may be something more critical.
Old Sep 20, 2012 | 06:59 PM
adolfo415's Avatar
Does a turbo from evo 9 10.5 help me to get more HP? cause I have good parts and I only made 279whp.
Old Sep 20, 2012 | 09:08 PM
steven121's Avatar
your boost needs to raised up of course, you can run 93 octane to squeeze more power out of it, your afrs should be at a certain point to burn better depending on how much power you want to make.
do you have just the injen intake or do you have the full injen setup? if its just the intake then there is most of your problem the the stock licp will hold back alot of power.
Old Sep 28, 2012 | 07:48 AM
thaoski_taicho's Avatar
where did you get it tuned?
Old Sep 28, 2012 | 05:31 PM
christian_21's Avatar
you should do a boost leak test before getting tune make sure everuthing is tight and zip tied
adolfo415
Oct 4, 2012 12:55 AM
adolfo415
Sep 28, 2012 08:33 PM
adolfo415
15
Sep 23, 2012 10:58 AM
alexso15
25
May 22, 2010 06:32 PM
mikenjulie
Feb 1, 2010 09:37 AM
