help needed ASAP!!!
help needed ASAP!!!
ok guys so i own a mitsubishi evo 7 and i am from Trinidad and got a major issue that i need some help with ASAP!!
the motor is a 2.0lr
PTE 6266 Dbb
stock intake
ets 4' intercooler
PTE 1200cc injectors
spark tech non cdi system
stock ecu tuned
hallman manual boos controller
bosch o44 fuel pump
aeromotive fuel regulator.
car made 518hp 30psi on VP racing C16
i am having a problem that when shifting gears while racing i am getting a breaking up /hold back while shifting for half second and then the car smooths out after. i changed the sparktech and installed the stock coils with a 22gap on the plugs which are DENSO 8's and installed a grounding kit and the problem is still there...
your help will be greatly appreciated... if there is anything else that you guys need to know about what the car has let me know... thanks
PTE 6266 Dbb
stock intake
ets 4' intercooler
stock ecu tuned
bosch o44 fuel pump
http://www.facebook.com/photo.php?v=10152681802330247
here is a face book link with a video of a race that i ran a few night ago... at 0.04 you will hear the problem...
I am not on Facebook so I can't see the vid, but I bet you are floating the valves. Exact same thing happened to me when I had stock springs and revved to 8200. What are your valve springs and what are you revving to? Try lowering your rev limit by 200 rpm and see if that solves it. Worth a try. GL
aka.ralliart15
Oct 27, 2010 08:09 AM
