TSComptuned: 2.4LR 6466 kelford 272 E85 43psi | 800hp~
Old May 17, 2013 | 04:26 AM
  #31
EvocentriK's Avatar
Massive numbers. Why does it just flatline from 6400 on 93?
Old May 17, 2013 | 01:51 PM
  #32
tscompusa's Avatar
Originally Posted by jessmanEVO
Nice! Try going with a different fuel setup for more fuel!
We're switching it to -8 AN feed.
because thats all the car will do on 93. it reaches its max # then holds it. atleast its holding it though and not falling down.
Gotta keep in mind the car has 272 cams, stock intake mani, stock head, stock tb, etc. some port work will bring this car alive a good bit more and a nice big 280 cam like a gsc s3 will do wonders for it uptop.
I'm working with another car also on a 2.4 with a 6466 but he has GSC R2 cams & is a evo 9 and is seeing full boost by 4700rpm (30psi) in 3rd gear. pretty impressive turbo no doubt.
Old May 17, 2013 | 02:42 PM
  #33
badev0's Avatar
Very impressive numbers for sure, especially for the stock parts that are on it. Does owner plan to hit drag strip with it at all?
Old May 17, 2013 | 03:26 PM
  #34
RyuEvoIX's Avatar
Brian may go to the track with me on Sunday. I'd like to see how squirrelly the car gets down the track with all that torque.
Old May 17, 2013 | 04:43 PM
  #35
DisgustipatedM3's Avatar
Good god this thing is a freakin monster. Amazing tune as always, Tom. I want to see this thing with GSC S3's and a badass intake Manifold like AMS F1i + 70mm throttle body. This thing with just a few tweaks will become even more incredible. Dat spool!
Old May 17, 2013 | 04:55 PM
  #36
tscompusa's Avatar
Yes absolutely this weekend.
I'm trying to talk him into letting you drive it down the track!
Thanks. Its certainly a team effort. Brian did a wonderful job on getting the car ready and everything is as it should be. But that is to be expected, he makes a living making sure airplanes are safe to fly.
You got it. S3 and a aftermarket or ported intake mani with a bigger tb like a 70mm will definitely put this car into another level.
Old May 17, 2013 | 11:13 PM
  #37
st00pidct9a's Avatar
Loving This
Old Jun 9, 2013 | 02:15 PM
  #38
JGNERAEVO9's Avatar
Originally Posted by tscompusa
** graphs updated for proper weight ** - car was taken to a weight station
ECU: Stock ECU / tephra v7 speed density / ecu boost
Fuel: E85 (Tested as E78 unless noted in graphs different)(multiple gas stations)
Loc: FL
Mods:
03' EVO 8 GSR
2.4LR 10.5:1 (Manley Turbo Tuff / Wiseco HD 1400)
ARP L19
Kelford 272
Spoolinup COP
FIC 2150cc inj
Big B Fab Double pumper /w -6 AN FEED
Big B Fab 6466 vband .82 a/r & custom top mount manifold
Big B Fab FMIC L 34.00" x H 11.50" x W 3.50"
Big B Fab 2.5" short route uicp
Big B Fab 2.5" licp
Big B Fab 3.5" exhaust aero turbine muffler
44mm tial V44 WG 13 psi large blue spring
50mm tial Q bov
forge unos mbc / Grimmspeed 3 port
omni 4 bar
4" SD intake K&N 4x9 filter
exedy triple HD
Graph: (as of 5-15-2013 this car is officially out of fuel at 770WHP - i can not get the car to go richer then 13's at high RPM at 44psi).
93 vs e85 tune:
made this at 34psi:
made this at 40psi:
engine bay:
ADD:
For those who browse and read this section of the forum for educational purposes and to learn what setups work best,
Id like to note this vehicle is using a H1528SP6051S 87MM .051 THICKNESS Cometic HG.
So this thing is not oringed and is not running thicker head studs?
Old Jun 9, 2013 | 02:34 PM
  #39
Jetfixrguy's Avatar
No o rings used, and standard 11mm arp L19 head studs. Nothing special.
Old Jun 11, 2013 | 01:05 AM
  #40
JGNERAEVO9's Avatar
What's the max power you can run with the Cometic and the L19s before needing orings?
Old Jun 11, 2013 | 06:14 AM
  #41
Lexus01IS's Avatar
How does the car run and idle on PUMP gas?
Old Jun 11, 2013 | 04:39 PM
  #42
Jetfixrguy's Avatar
I really don't know what the max power level is with this head gasket nor with the L19's but I do know that deck and cylinder head smoothness are extremely important on these 2.4's
Old Jun 11, 2013 | 04:43 PM
  #43
Jetfixrguy's Avatar
The car runs great on pump gas. No issues. The a/f swings a bit at idle (13.2 -14.5) but it dosen't affect the drivability of the car. With these large injectors they love E85.
Old Jun 12, 2013 | 05:02 PM
  #44
Lexus01IS's Avatar
I am trying to decide on injectors but we do not have E85 here. I will be running race gas. I dont want to get huge injectors if pump gas drivebality is bad.
Old Jun 13, 2013 | 07:01 PM
  #45
tscompusa's Avatar
Go with some 1450cc fic then. if you need some pm me.
