Cam Comparison with MAP 2.3L 6466 S3 vs S2
Old May 30, 2013 | 09:53 PM
tscompusa's Avatar
Originally Posted by 03whitegsr
I think you misunderstood what I said. We are on the same page though, in a back to back with the same boost level, the S3s will match torque and spool of the S2s while gaining a ton up top. It is a very impressive result.
That's what I figured. I've tuned above 45psi on E70 and it still reached MBT without detonation. Just thought I would ask why it was so rich.
Ya we are definitely on the same page. i did misread it then.
ya anything 70% and over is pretty potent. yep no problem i understand.
Originally Posted by evo4nr
same boost level would be better.
i'll get that done then. we just ran 40psi through the car and it made really good power. its holding solid till redline. im thinking im gonna just bump the boost mid range and raise it as the RPM's go up that way he can actually still use the car in 3rd gear and not roast tires off.
Target boost pressure will be 44psi for this application once finalized in the upper rpm's.
Tq curve was a solid curve sitting right around 600wtq so the car is definitely going to move out.
I have R2's here i could send him, but i doubt he will want to change cams again. but i'd definitely let him borrow them to test out if he really wanted to.
Old May 31, 2013 | 12:15 PM
evo4nr's Avatar
We did a straight swap to s3's from s2's and they were 300rpm difference in spool at the same boost level.
Do you time cams or fit with stock pulleys
Old May 31, 2013 | 08:51 PM
Steven's Avatar
I installed these with stock pulleys. I pulled the S2's out, installed the S3's, then Tom sent me a rom with less boost to make a pull. I pretty much made similar power numbers on the first rom and lost very little spool. We could pick up plenty of power mid-range by increasing the boost levels with the grimmspeed, but I blow the tires off with anything more aggressive.
I can brake boost around 70mph and spin tires the rest of the way through 3rd. Old asphalt roads will often spin in 4th. It is a fun car!
Old Feb 10, 2014 | 05:54 PM
Levar's Avatar
Veteran: Army
My two options are the S3 and the R2 cams. Time will tell.
Old Feb 11, 2014 | 11:40 AM
tscompusa's Avatar
Both work really well. The R2 have about the same top end as the S3 almost.
Originally Posted by SheepeyBuilt
If I may ask:
What wer the lobe centerlines on each cam from one set to the other?
GSC lists their data and I think kelford does also. I dont know the answer to that question though.
I will also add though, that both set of cams were not degree'd and installed straight up.
Old Feb 11, 2014 | 05:09 PM
Levar's Avatar
Veteran: Army
You had to throw that second "almost" in there, huh?
Old Feb 12, 2014 | 01:29 AM
EVO(boss)'s Avatar
wow great test , But if u dont mind can u tell me the rpm Idel on this car after the s3'
Im having an Idel problem on my car that I cant go lower than 2000-1850rpms on the Idel .
the tuner told me that becouse of the Big AMS head Im running .. he could be right
Old Feb 12, 2014 | 02:14 PM
5LEEPERISAH23I's Avatar
sick numbers! S3's are the real deal.
Old Feb 13, 2014 | 04:17 PM
batty200's Avatar
1800-2000rpm idle is ridiculous. There is no good reason for that.
Old Feb 13, 2014 | 05:41 PM
tscompusa's Avatar
The size of the head would have no affect on idle rpm. There's no reason you cant idle your car around 1000-1200RPM.
Even when i ran my car with no FMIC on it with both pipes open and exposed to the atmosphere my idle was still rock solid at 1100RPM on s3's.
Heres a video of that. http://www.youtube.com/watch?feature...GVcRHJE8#t=202
With Mivec they can idle even smoother also. My car is non mivec.
Old Feb 16, 2014 | 02:42 AM
EVO(boss)'s Avatar
so it needs a tune .. my car idel now 2k soo noizy ... we gonna see Im changing my setup with refrish the engine and run super99 turbo ...
thank u sir
Old Feb 16, 2014 | 02:54 PM
Evo9_Dubai's Avatar
My car idles perfectly with Toms tune.
Regardless, great numbers and comparison
Old Dec 14, 2014 | 07:12 AM
High_PSI's Avatar
So for us 2.0 guys s2's would be the better choice or suffer serious lag.
Old Dec 31, 2014 | 07:32 PM
tscompusa's Avatar
Pretty noticeable lag yes. If you are concerned with spool up you certainly do not want s3 cams with a 2.0L
tscompusa
Aug 20, 2015 03:58 AM
tscompusa
Nov 13, 2014 12:12 PM
tscompusa
Mar 4, 2014 12:57 PM
tscompusa
Dec 23, 2013 04:35 AM
tscompusa
Jul 12, 2013 10:43 PM
