EVO 9 MAP 2.3L MAP Top Mount 6466 GSC S3 E85 43psi 800whp+
Stock t-case and just a basic Jack's Transmission upgrade using an VIII 3rd and 4th. They've both taken a beating after several years at 520+ on the FP Red and are still going strong. I used the ACT HDSS clutch and now the Quarter Master 8-leg street/strip setup. I really can't complain.
I've been using the Denso IKH24 plugs gapped at .018-.020. I have to replace them about every 3-6 months due to slight fouling from cruising around town. I've thought about going back to stock NGK's, but I'm afraid of inducing detonation at this power level.
Thanks!
Have you tried iridium plugs?
Same question MAP and but also the the twin scroll 6766 vs this top mount 6466 as both are in $4800ish rangr.... I am just debating between those two for over 700whp range street car.
the turbos not edible though
Thanks Pete.
yep. i think its finished due to the stock lines right now also.
black on black theme never gets old if you ask me.
I dont know crap about exhaust manifold stuff, but i think you're right. the longer runners make more peak hp , the smaller runners help with spoolup.
Ya plenty of 6262/6266 cars over 700whp. its all in the supporting mods.
