Stock Evo 8 Min Mods
Subscribe
Jul 9, 2013 | 06:51 PM
Well I decided it was time to do some tuning on the car since I was seeing a little bit of knock. The following is the mod list.
3 inch exhaust with no cat
Omni 4 Bar Map
3 Port BCS
Boost was around 24psi then drops to around 22ish.
93 octain
Smoothing was set to 1. Moving it to 6 dropped it around 6 h/p. It is still rich as I know but its a lot better then what it was. Im only seeing 1 count of knock. Im sure once I lean it out a little it should hit 300. I also know that I can mess with the timing a little since I see its falling off up top. Just ran out of time. P.s. this is on stock fuel set-up, and I weigh 200lbs.
Reply 0
Sep 14, 2013 | 12:22 PM
not bad for basic mods
Reply 0
Oct 2, 2013 | 10:06 PM
pretty good numbers for less than minimal mods congrats
Reply 0
Oct 3, 2013 | 10:35 AM
Did you stop the pull at 6600, or just cut the graph to 6600?
Reply 0
Oct 3, 2013 | 03:03 PM
I believe you should be at 310-320whp 320-350ftlbs (VD Dynojet) at that boost level.
You are overfuelling your car, 10.3 is waaaay too rich. Keep it 11.5-ish, not any richer than 11. You can also make it leaner at spool up like 12-ish tapering to say 11.8 at peak boost..
Reply 0
Oct 6, 2013 | 09:51 AM
Good power man
Reply 0
Oct 6, 2013 | 07:11 PM
I let off the gas at that rpm so VD stops there. (Since it uses 100% throttle cells to graph) And yes i know 10's are rich, it was a conservative tune. I didnt have time to fully tune it when I made these pulls.
Reply 0
Oct 11, 2013 | 03:09 PM
Nice numbers. Have you made any updates to the tune?
I'm running a Walbro, 3-port, Omni 4-bar, and a drop-in. Still learning to tune but hopes are high!
Reply 0
Oct 11, 2013 | 11:21 PM
Quote: I believe you should be at 310-320whp 320-350ftlbs (VD Dynojet) at that boost level.
x2
I'd be curious to see your timing on that run.
suscribed for 11.5 AFR results..
Reply 0
Oct 13, 2013 | 07:24 AM
Wont happen haha. I took the 2.0 out and threw in a 2.4
With stock turbo im around 370hp and 380tq.
Reply 0
Oct 13, 2013 | 03:55 PM
nice, a 2.4 stock 9.8 turbo must feel like a feather
Reply 0
Oct 13, 2013 | 07:54 PM
Haha it does.
Reply 0
Subscribe
