Do I need a re-tune due to added modifications?
Old Nov 7, 2013 | 07:59 AM
UMIR3N's Avatar
Hey guys,
Just hoping you can answer a quick question. My evo VIII has been tuned after fitting a TBE, Walbro fuel pump and k&n panel filter. I am about to install the Injen intake and full lower and upper intercooler pipes provided in the kit and was wondering if my tune needs to be re-done to accommodate these mods?
Thanks.
Old Nov 7, 2013 | 08:07 AM
ReaperX's Avatar
You'll need to add a little fuel up top for the intake. If you're using a 3-port for boost control, a .5% increase in duty cycle for the licp.
Old Nov 7, 2013 | 08:12 AM
InoNothingMR's Avatar
Yes, you should re-tune after just about any engine modification. The car is getting a different flow due to the parts and will not know how to handle them correctly.
Yes, the car should run fine if you do not tune. But it will run better if you re-tune it and you will also be able to get the most gains out of your additional mods.
Old Nov 7, 2013 | 08:14 AM
UMIR3N's Avatar
Thanks guys, I just needed reassurance that the added mods would alter the current tuning abilities.
Old Nov 9, 2013 | 06:28 PM
rstchris's Avatar
The intake will make a significant change in the maf frequency, the charge pipes are really a non-issue. I would only worry about it if you feel your timing being pulled or unless you have Tephra's "knock on cell" then retune only if needed. That money can be spent elsewhere.
Old Nov 10, 2013 | 03:43 PM
mitsubeastlee's Avatar
I think allowing more airflow into the engine ie full intake and lower intercooler pipe along with everything else you posted allows the engine to become more efficient and make more power you should retune not only to be safe but to reap the power/response benefits. Anytime you mess with fuel (fuel pump, injectors, etc) its wise to get your logs checked out BARE minimum
Old Nov 10, 2013 | 07:31 PM
JaYr_EvO9's Avatar
Originally Posted by UMIR3N
Hey guys,
Thanks.
it kinda the thing to do too see the best results but you can install the parts and drive around until an tune... Depends do you wanna pay 200-500 for something small like that NO lol But for best results yea.....I install all those parts and drove around a little bit with out a tune
Old Nov 16, 2013 | 08:00 AM
Dannym550's Avatar
Anything affecting air or fuel short of a new filter should be tuned!
Old Nov 19, 2013 | 11:29 AM
Redliner23's Avatar
I just bought an injen intake of an E8 for my E9. Would it be ok to put it on and run it for now or should i wait and get icp then put them all on together and then tune?
Old Nov 20, 2013 | 03:14 PM
Black_EVO_MR's Avatar
I recently installed:
ETS 3" intercooler
Injen Intake, Lowe and upper piping.
Megan Exhaust Manifold.
Buschur downpipe.
Works test pipe.
Greddy TI-C cat back exhaust.
Aluminum Radiator (little bit thicker than stock)
Have not got a tune done yet, still looking for a trusted tuner in my area, but ive been driving my car around and no problems. Im sure it would do much better once tuned.
I have no clue what kind of # im gonna make. Anybody has a clue? Anybody had similar mods?
Tommyfacekicker
70
May 20, 2017 09:56 PM
Anthony Aguirre
Feb 8, 2017 03:20 AM
drifthobo
For Sale - Wheels / Tires
Mar 5, 2011 02:53 PM
A-SPEC
Evo 'For Sale' Wheels / Tires
166
Nov 18, 2008 05:10 PM
ecuflasher
14
Aug 20, 2008 10:06 AM
