cheap 25G home made turbo testing
Stock Block
Kel 272
ETS FMIC
ETS LICP
ETS UICP
MAP O2 DUMP
FP 25 PSI WGA
OEM COIL PACK *HURTING THIS SET UP*
Tial BOV
3" down pipe
Turbo is a 10.5 hotside turbo with an 84mmX60mm wheel with 6 blades by turbo labs....at 34 psi it still wanted more boost....and it was being redline at 7000. Slight uphill incline on the dyno pull too.
C16 FUEL VP RACE GAS
No anti surge housing wanted stealth look
Wish we would of gone anti surge and done a pull up to 8000 rpm...cant find flat road so slight up hill incline
For 650 bucks though sending in hotside were happy
Would love to see this with a 2.4, anti surge, r2 camshaft on dual pump....
Would make 600 whp
This section should be used to educate people. when you post a VD graph that looks like it went through photoshop and blocks out all data, it really does no good to the average viewer.
Ask your tuner to give you the full unedited next time!
Also as long as you are not blowing out spark (misfiring) the OEM coil pack wont hurt you at all. I have some cars that went 143+ in the 1/4 on the oem coil packs.
Gap your plugs around .018" and you'll be fine!
I agree, torque plot, AFR and Boost plot vs RPM out of Virtual Dyno should be posted. Your plot doesn't even list correction factor. It screams somebody is fudging something.
It says when peak torque was but am not happy with it since it was up hill. I am sure car is over the 550 who range. Will retest though in a few weeks. Coils died out the next day. Borrowed spoolin up from a donor car and its back alive. Tuner recomended .014 gap which is crazy but heh has tuned 8 second cars so knows best.
Afr were in the 11.5 range and in the 12.5 during spool up. Wideband does not log with evoscan so it was tuned old school by naked eye. Will address this just for my sake. My tuner doesnt really need it.
Ya if its blowing spark and the gap is tight and the plugs are good then yes ignition will hurt power.
I tune with RPM gauge & wideband also on some customers who dont like to wire in the AFR. As long as you can see the afr gauge and the RPM tach in the same view its no different to someone who knows what their doing.
I gap my silver evo with a 6466 at .015" on iridium plugs with a sparktech non cdi.
Raced a GTR and STI on the street
In intensive 4 hour road tuning session. One of the things I told them was that I didnt want to use any fancy high zinc type of oil. So far its been durable will constantly be posting dyno graph of this car as improvements are made.
evo8vz
Aug 4, 2016 05:00 PM
ETS Michael
Mar 31, 2012 05:49 AM
Gary@MellonRacing
Oct 27, 2011 01:56 PM
