Evo 8 2.1L MAP EF3 GSC R2 cams E60
He should do a leak down test. I've noticed mivec heads do make compression test results lower. On my old set up with FP4R cams on both a built 2.0 and a stock one I was in the low 100 range. On a 2.4 with 9.5;1 pistons about 120 psi and in all cases leak down was with in spec. There is no way his car run well let alone make that kind of power if the compression is that much lower than it needs to be.
tscompusa
Oct 10, 2018 12:43 PM
tscompusa
Oct 17, 2015 12:03 PM
tscompusa
Jul 4, 2015 02:02 AM
tscompusa
Feb 27, 2015 05:45 PM
