Why be afraid of big turbos?
Old Sep 4, 2014 | 09:39 PM
  #46
DsmGuy86's Avatar
Wow I'm in for learning stuffs..
Old Sep 4, 2014 | 10:27 PM
  #47
jbenosa's Avatar
+1. i like discussions like this, i'm learning alot as well.
Old Sep 5, 2014 | 08:09 PM
  #48
batty200's Avatar
A cam on bucket is not quite like a flat tappet because the bucket spins under the cam so it doesn't drag straight across. It still isn't as nice as a roller.
Old Sep 5, 2014 | 09:21 PM
  #49
94AWDcoupe's Avatar
flat tappets spin in their bore as well.
Old Sep 8, 2014 | 07:36 AM
  #50
03whitegsr's Avatar
94AWDcoupe, this is like ME101 here, but you are neglecting contact angle. Just because the lobes are different doesn't mean much.
Flat tappet cams actually have an issue with having too much jerk. The contact point is in the center of the bucket while the base circle is active. However, the contact point quickly goes to the edge of the bucket as the lobe comes active, the vast majority of that flat area on the ramp almost doesn't even touch the bucket and the nose of the cam becomes active very quickly.
Adding rollers actually reduces the contact angle movement and makes the cam less aggressive. This is why roller cams LOOK so much more aggressive. Unless you are looking at actual valve movement, and not just measured cam profile, you can't really compare cam lobes like you are trying to.
The limits of a flat tappet cam, like the 4B11 is the diameter of the tappet and then what kind of jerk and accelration rates the valvetrain can handle, along with side loads placed on the assembly due to the contact point being WAY off center at the highest acceleration point.
If somebody wants to take some measurements though, we could built up a quick model and I think you'd be pretty damn suprised how aggressive some of these cam over bucket setups really are.
Old Sep 8, 2014 | 09:08 AM
  #51
JohnBradley's Avatar
I can ask Greg if he can supply some information.
Old Sep 8, 2014 | 10:22 AM
  #52
94AWDcoupe's Avatar
03white you added nothing to the conversation that shows 4g63 cams are not as aggressive as they look. they look aggressive because they are. you guys are making this waay more complicated than it is. cam profile is just that. cam profile. someone can post graphs of cams from same manufacture will only confirm everything I have said. untill then I have nothing to add.
Old Sep 8, 2014 | 12:29 PM
  #53
mrfred's Avatar
Jerry, I think what 03white is saying is that because the way a flat tappet cam makes contact with the tappet/bucket, a wider valve opening duration will take place compared to if that same profile were used as a roller cam. No doubt though that the roller cam can acheive valve openings that are not possible with a flat tappet cam. I have no idea though whether the cams we use in our 4G63 Evos make use of that capability range.
Old Sep 8, 2014 | 05:10 PM
  #54
03whitegsr's Avatar
94awdcoupe, just because you didn't grasp what I said doesn't mean I've added nothing.
Let me sum it up with a simple statement of what I said.
Unless you are charting actual valve motion, you are simply guessing which is actually more aggressive.
Old Sep 8, 2014 | 06:56 PM
  #55
Lexus01IS's Avatar
I applaud English Racing for trying different than Evo norm.
Old Sep 9, 2014 | 01:16 PM
  #56
murlo26's Avatar
Trying to sell something there buddy?
Old Sep 9, 2014 | 06:28 PM
  #57
Migsubishi's Avatar
Originally Posted by S0ul Ev0
Never be afraid of big turbo !
Unless it's on the other car your racing against.
Old Sep 9, 2014 | 09:00 PM
  #58
mrfred's Avatar
Old Sep 10, 2014 | 03:48 AM
  #59
tscompusa's Avatar
well said
Old Sep 11, 2014 | 06:12 AM
  #60
bsh's Avatar
bsh
Originally Posted by bsh
That is very impressive spool for a 7175 on 2.2
Can you please show the graph with time on the X-axis instead of rpm?
Originally Posted by JohnBradley
Tuesday when I get back to the shop.
Hello
Can you please show the graph with time on the x-axis?
Thanks
