6466 psi limits???
Old Sep 7, 2014 | 12:23 PM
Migsubishi's Avatar
6466 psi limits???
Has anyone ever taken a Precision 6466 to or past 50psi?
If so what were the numbers?
I've heard of this being done with the 67 and up but not the 6466, just curious.
All factual input is welcome.
Old Sep 8, 2014 | 09:31 AM
JohnBradley's Avatar
We made peak power at 43-44, past that it wasnt flowing much. 906whp is moving some air for a 6466.
Old Sep 8, 2014 | 09:36 AM
Migsubishi's Avatar
Nice, thanks for that info!
I guess instead of making posts, I should just pm you. lol
Old Sep 8, 2014 | 10:42 AM
AngryEvo8's Avatar
Last year I made 850 @ 48psi on a mustang dyno. Its not 50+ but close. I believe Joey V passed 50 up on the Junkbox when the 64 was on his car.
Old Sep 8, 2014 | 10:48 AM
5LEEPERISAH23I's Avatar
How efficient is it past 43-44 PSI tho? currently at 37-38 and ever PSI added from 34 and up it is showing im gaining 12-14 whp ish.
Old Sep 8, 2014 | 11:01 AM
AngryEvo8's Avatar
You'd have to put it to the test to find out. Each car is different and depending whats done might yield different results. I was still making power but my fuel pumps couldn't keep up.
Old Sep 8, 2014 | 04:22 PM
Migsubishi's Avatar
How much power do you make now? Heck 10 more psi at 12hp per psi would be another 120hp.
Old Sep 8, 2014 | 05:58 PM
How much boost did you run for the 9.26@150 and how much did the car weigh?
Old Sep 8, 2014 | 06:39 PM
CT9A PR's Avatar
We have taken one 51 psi plus 125 nitrous on a 2800 lbs car
Old Sep 8, 2014 | 07:00 PM
Migsubishi's Avatar
And???
How did that work out?
What power did it make?
What did it run?
Did the turbo stay together?
Old Sep 8, 2014 | 09:49 PM
ch53avitech's Avatar
Good to know that this turbo is capable to so much.
Side note how can you make 900hp at 43psi? I'm making 670hp at 36psi. Not trying to call you out or anything just trying to figure out how I can achieve that power with this turbo.
Old Sep 8, 2014 | 10:06 PM
Migsubishi's Avatar
Boost (psi) is an actual measurement of your engine inefficiency to flow air. The more psi you need, the more of a restriction you have.
If you have the right combo, good head work and cams combined with everything else that works great together, you can actually max a turbo out before 40psi.
Some engines flow better than others and require less boost (psi) to do the same as others do that need a lot more psi to achieve the same results.
Old Sep 8, 2014 | 10:20 PM
Yes.
Boost is backpressure in the intake manifold. Get VE and rpm where it needs to be and you can make 900whp at 10psi.
Old Sep 9, 2014 | 06:55 AM
mrfred's Avatar
Originally Posted by JohnBradley
Yes.
15k rpm and 120% ve?
Old Sep 9, 2014 | 08:06 AM
CT9A PR's Avatar
Turbo still together
Car ran 8.9 with out nitrous
Car over heated when it wax tuned oj pump gas with 10:5:1 compression on 91 octane
Car had double 450 walbro
255 wouldnt hold up
2650cc injectors
