2006 IX MR results
Old Nov 14, 2014 | 10:04 AM
nomoretransam's Avatar
2006 IX MR results
Big thanks to FFTEC for making this boy a lean mean V8 killing machine..HAHA
429AWHP on E85
370AWHP on 91
Mild tune. Could have made more but didn't want to overstress anything.
The list of Mods:
-GTWORX SPRINGS
-GM 3-PORT SOLENOID WITH A DONGLE
-FFTEC MANUAL BOOST CONTROLLER
-BBK FULL TURBO
-INVIDIA O2 HOUSING
-3" PERRIN DOWNPIPE
-TURBOSMART INTERNAL WASTEGATE ACTUATOR
-SRP RACING PEDALS
-WORKS MR SHORT SHIFTER
-WHITELINE 26mm FRONT SWAY BAR
-BEATRUSH FRONT CENTER BRACE
-BEATRUSH PERFORMANCE FLOOR BAR
-ULTRA RACING FENDER BAR
-DME REAR STRUT BAR
-EXEDY HD TWIN PLATE CLUTCH
-CUSCO HEAT SHIELD
-MISHIMOTO RADIATOR
-BUSCHUR RACING 65mm THROTTLE BODY
-ARP RADIATOR COVER
-ETS 3.5” WIDE TANK INTERCOOLER
-MAX SHEP TRE 12 PLATE REAR DIFFERENTIAL WITH SIGHT GLASS COVER
-TORQUE SOLUTION ENGINE MOUNTS (PASSENGER SIDE, FRONT SIDE, TRANSMISSION SIDE).
-INVIDIA 02 HOUSING
-TORQUE SOLUTION BUSHINGS
-GREDDY OIL CATCH CAN
-CUSCO POWER BRACE TRUNK
-CUSCO CENTER BRACE
-AEM INTAKE KIT
-NISEI LICP/MINI BATTERY TRAY
-GRIMMSPEED MASTER CYLINDER BRACE
-STILLWAY ENGINE DAMPER
-DRILLED & SLOTTED ROTORS
-WALBRO 400LPH FUEL PUMP
-FUEL INJECTOR CLINIC BLUEMAX HIGH-FLOW DSM/EVO INJECTOR SET 1250CC INJECTORS
-NEW EBC REDSTUFF 3000 BRAKE PADS CERAMIC
-ETS UICP (SHORT ROUTE)
-NEW ODYSSEY MINI BATTERY
-CUSCO FRONT STRUT BAR
-COSWORTH M2 GRIND 272 DEGREE INTAKE/EXHAUST CAMSHAFT
-SUPERTECH DUAL VALVE SPRINGS AND RETAINER KIT
-ARP HEAD STUDS
-CURT BROWN PORTING SERVICE OF INTAKE MANIFOLD, EXHAUST MANIFOLD, THROTTLE BODY, O2 HOUSING, AND TURBO HOTSIDE
-ZAKLEE CAM GEAR COVER
-SYNAPSE SYNCHRONIC MINI DIVERTER VALVE
-NEW BF GOODRICH G-SPORT TIRES
Old Nov 14, 2014 | 10:15 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Where's the dyno chart?
https://www.evolutionm.net/forums/ev...ee-inside.html
Old Nov 14, 2014 | 10:25 AM
ETS Michael's Avatar
The guys over at FFTEC know what they are doing. Congrats on the new found power.
Old Nov 14, 2014 | 11:00 AM
dyno chart is up in the garage. Ill take a pic and post her up
Old Nov 16, 2014 | 09:46 AM
scopy's Avatar
good to see an all around sound build instead of just mad high numbers. should do great for track/road racing.
Old Nov 17, 2014 | 06:26 PM
stefenboy's Avatar
When did you get your car tuned? I tried calling them but they no longer tune evo 8/9... = (
Old Nov 18, 2014 | 11:35 AM
arman.hamzic's Avatar
Awesome numbers!
05blue8
Apr 11, 2009 06:51 PM
Freddy302
77
Feb 10, 2008 09:20 AM
Pete
Oct 30, 2006 03:33 PM
tcarretti
16
Apr 26, 2006 10:37 PM
dlowman
17
Sep 25, 2004 11:46 AM
