FP zephyr 702hp/532TQ 10.02@144
Old Aug 19, 2015, 06:05 AM
Jwhalen07's Avatar
I have been testing out this new xona rotor CHRA and 57/79mm compressor wheel stuffed into a stock frame for FP. The engine combo is a 11.5:1 CR custom Wiseco HD, Pauter rod 2.0L with some developmental port work I have been trying out some neat valve combos. Ferrea/stock valves, Kiggly springs and HLA. I have a stock intake manifold/stock throttle body that I modded back in the day and really want to test vs a stock one. Also running a stock exhaust manifold.
Just for reference sake I included compressor wheel sizes and links. The turbo fits right in between the FP red and the FP black for compressor size and they share the same turbine housing design and compressor cover.
FP Zephyr is rated at 65-70 lb/min-- compressor wheel 57/79mm HTZ
http://www.forcedperformance.net/mer...=NTEVOFPZephyr
FP red is rated at 59lb/mib-- compressor wheel 54.8/76mm HTZ
http://www.forcedperformance.net/mer...e=Lancer-Turbo
FP black is rated at 68 lb/min-- Compressor 59.1/82mm HTZ
This was the last pull before I loaded the car up for shootout. I was fighting some ignition breakup but she was clean at the track. Running standard toyota coils in sequential fire.
I spike 44psi and fall to 38psi
https://www.youtube.com/watch?v=5i8006_4gm0
I'm going back to the track this weekend. Might remove some seats and panels to drop the weight. Car weighed in at 3220 with me in it.
Overall crazy power bolting a turbo onto a stock manifold.
Steveevoix (Nov 12, 2017)
Old Aug 19, 2015, 06:43 AM
Evo8cy's Avatar
Nice results on the zephyr!
Marios
Old Aug 19, 2015, 07:36 AM
06MREvo's Avatar
Awesome, congrats again on your win at the Shootout & good luck at the track this weekend.
Can't wait to see what this turbo will do on my 2.3 setup. I hope to have my car under 2950lbs with me in it. I weigh 195ish.
Old Aug 19, 2015, 09:25 AM
dsmchiz's Avatar
Whoa great power and numbers!
E85 I assume?
Old Aug 19, 2015, 11:21 AM
SiriusEvo's Avatar
Congrats
Props to Whalen R&D
This is no easy feat on a stock frame turbo setup. Well done. I look forward to seeing this car in the 9's
Old Jan 17, 2016, 12:38 AM
balls_deep_evo's Avatar
Just wondering if you could give an update/ review on the zephyr after having it on for a while now?
Old Jan 18, 2016, 07:03 AM
06MREvo's Avatar
He removed it from the car a while ago & has a completely different setup now.
Old Jan 19, 2016, 03:19 PM
Jwhalen07's Avatar
I play to much to leave a turbo setup or engine package in the car for more than a couple months. I sold this turbo setup to my brother in law. He has a 2.3L Evo 9 that we are going to play with come spring time. I'm hoping for a fat powerband on his stroker mivec setup.
balls_deep_evo
Jul 12, 2018 09:06 AM
dsmchiz
Oct 8, 2015 12:37 PM
Michael @ FP
Oct 6, 2015 06:57 PM
autoplus
Sep 5, 2005 06:55 AM
DynoFlash
Jul 25, 2005 06:32 PM
Quick Reply: FP zephyr 702hp/532TQ 10.02@144
